Question about Beko 24 in. D3421F Free-standing Dishwasher
Beko cooker model DC211B
Hi Bud
I need a circuit wiring diagram for a Beko Electric Oven Model DC211B
I am exchanging the Grill Regulator,but the wires are faded with age and become Brittle ,I have alreadywired the regulator & must have made a wrong connection ! Hence theGrill did not work .
After turning on the Hot Plate Knob No 3 itBlew the Hotplate Selector Switch & caused a Short ,thus leavingthe Neon indicaitor permantly illuminated ?
I suspect that the Hot plate Selector Switch had arked out and now U/S .
The Grill Element is okay ! .
Ciurcuit Breaker for the Cooker Tripped out as designed to do so in Consumer Unit .
Hopefully the damage to the Cooker is Fairly Minimised ?
Priorto changing the Grill Regulator which had evidence of Burnining andChared Wires, DO YOU THINK THAT IT IS WORTH REPAIRING ?
If you canSupply me with a diagram or any knowlege of what wire goes to eachterminal of the Regulator it would be a great Help .
Many Thanks
Pete
  • Anonymous Mar 19, 2014
    why has my beko cooker gone very rusty after nearly 4 years model no dvc663w
Hi
many thanks for your reply ,I suspected that a charge may be applicable for your guidance of how repair the Fault .
Hence enough money spent as I was not happy with the wiring of the appliance as it would not have passed a P.A.T. .
I have purchased a New Cooker Model DW531 as the appliance is for my Disabled Brother & his Wife (Trade Price )
Many thanks
Mginty
Posted on Jun 29, 2008
I have power but not switching on at Knob no grill or oven no fan
Beko OIF21300B Electric Single Oven not heating - Repair
www.how-to-repair.com/.../beko-oif21300b-electric-single-oven-not-hea...
Jun 11, 2015 - If your Beko OIF21300B Electric Single Oven is not heating or tripping the ... Now the cooker turns on and the display lights come on but the cooker does not seem to work and start heating up. ... The grill element doesn't work
[PDF]Download Manual - Beko
downloads.beko.co.uk/bekoupload/manuals/DVG592.pdf
Congratulations on your choice of a Beko quality cooker which ..... Before you startusing your cooker, clean ... if an appliance burner doesn't light, press again.
Dec 13, 2015 | Beko D533AW Single Fan Oven Electric...
Beko s502 cooker
how do you know the maximum temperature that this appliance can reach? how do you measure it?
Normally, electric cookers can be wired in many ways, according the mains (1, 2 or 3 phase). if the cooker is connected to only 1 or 2 phases (less power) it can be SLOW :-)
hope this helps!
Sep 19, 2013 | Beko Dishwashers
Beko oven
If you have a problem with your beko cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jul 06, 2013 | Ovens
HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
Jan 29, 2011 | Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
    If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 15, 2011 | Ovens
Our beko dv 555 w double oven bottom oven is not working as the clock display is not on
Beko DV 555w Electric cooker.Oven and clock is not working.
The hob and grill work.
Nov 19, 2010 | Ovens
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Beko D533 cooker only half working
where the power goes in there should be fuse links on both sides if they all in then its the thermal fuse inside
Dec 07, 2008 | Ovens
Beko double oven electric cooker - bottom oven (fan assisted) doesnt come on, rest of cooker works fine
Oct 03, 2008 | Kitchen Ranges
Beko 24 in. D3421F Free-standing Dishwasher Logo
520 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
