Question about Epson AcuLaser C3000 Printer
How to fix paper jam Epson CX3650? - Epson AcuLaser C3000 Printer
Hgjhdyejjdffh
Posted on Nov 17, 2008
The paper jammed on the right side as it is about to come through the rollers. It is an accordian like paper jam and as small as my hands are, I cannot grasp the small edges to pull out. I see no other way of getting to the paper. Any suggestions?
pat
Posted on Jul 11, 2008
    Guru:
  • 1,894 Answers
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
THANK YOU
REGARDS
SWEET RASCAL
Posted on Jun 28, 2008
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
I have lost the CD instalation disc. Can you
Support for Epson CX3650 on next site:
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-CX3650/Drivers-Support?supportLandingPage=true
Automatic operating system detection, when wanting to install on the computer used for the downloads.
When wanting to install on a computer with another system, select yours.
Oct 11, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Manunal for epson stylus cx3650
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20CX3650-_S
Sep 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Cx3650 Problem with paper feeder
There could be an issue with the gear inside your printer now that is why it is not feeding the paper through properly anymore. Please try this basic troubleshooting steps:
Turn off the printer. Disconnect the USB cable from your printer. Open up the whole scanner unit to see if there are objects blocking the way of the printhead or if there are any objects down the paper feed area. Check if the cartridge cover is closed properly. Toggle the paper guide left to right back to the proper position. Load 10 to 20 sheets of regular paper into the printer. Turn the printer back on. Do a standalone copy.
If it does the same thing, please log on to support.epson.com. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
May 12, 2009 | Office Equipment & Supplies
Scanning function of Epson Stylus CX3650
To scan using a multi-function printer, you need to install the software on your computer. Do you still have the installation disk for your Epson stylus CX3650? You may download it from here: http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=nKGrQtfEm6nFHFTrlaTOjFTqtAMM0p7d3pb4dtXdKsIU003D&tc=6
Hope it helps!
Oct 21, 2008 | Epson Stylus Multifunction Inkjet Printer/...
I was given a epson all in one cx3650 but i dont have the instructions with it
Hey there hicken, the following website will present you the option of downloading the manual, as well as the drivers and software for your machine which they refer to as a Epson Stylus CX3650. It is free of charge.
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=nKGrQtfEm6nKBzp6xBy1M39Kbr2mxl1f5LU002FpTTBuEnUU003D
Just copy and paste, and you are good to go.
Feb 04, 2008 | Computers & Internet
Epson CX3650 Printing Only half a page
This may sound nutty, but I have an epson stylus cx3650, with the same INFURIATING problem. And I think I *may* have just fixed it. and its daft, and simple, but we all know how picky printers can be!
Okay, the paperfeed at the top, on the left hand side is a grey slide, (right in the printer) to hold the paper in place. USE IT to keep the paper straight, it seems, if the paper goes in straight, the whole page is printed. I don't know how or why but it worked for me! ^^ (and this is after the printer was stored in a cupboard for a year, because of this problem!)
Nov 08, 2007 | Office Equipment & Supplies
Epson AcuLaser C3000 Printer Logo
402 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
