Question about Nikon Speedlight SB-800 TTL Flash
Flash wouldn't stop flashing
Hi.I have been using sb800 for over a year.Lately it has given me alot of problem as flash keeps on flashing and batteries wouldn't last at all even though i use 2700amh batteries which use to last aimost 300 photos and now only about 30.Please send me a solution on how I can fix i
Many Thanks
Asim Mir
  • 3 more comments
  • morganm Aug 07, 2008
    I have noticed that my Sb800 flash hs started to flash on it's own when I'm not taking a photo.
  • kevin307 Aug 12, 2008
    Same thing here, last week it flashed constant for almost 3 seconds I suspect it could be the cells, they are rechargeable, sometimes it works fine. I have had the misfires on D70, D200 and D300 so I'm sure it a problem with the flash.
  • coentjien Aug 15, 2008
    While zooming or changing aperture the sb-800 fires several little flashes on its own. Objective Nikon 28-105 and Nikon D50.
  • Anonymous Nov 14, 2008
    I have the same problem.  I also notice that the focus assist also then functions on the flash as well
  • Anonymous Dec 24, 2008
    same here.. when I'm just focusing or zooming, it would fire unexpectedly for no reasons whatsoever... what's going on!???
SOURCE: SU-4 on sb800
Unlock The Superslave in Your Nikon SB-800 http://strobist.blogspot.com/2007/08/unlock-superslave-in-your-nikon-sb-800.html
Posted on Dec 31, 2007
andrewscool
  • 22 Answers
SOURCE: sb800 will not flash
To reset the device, hold down the "MODE" and "ON/OFF" buttons at the same time for about 3 seconds.
Hopefully that will do the trick. if not you cant contact me for further help!
Posted on Jan 15, 2008
  • 216 Answers
SOURCE: sb800 doesn't flash
Let's force the flash to fire:
nstalls four fresh batteries.
Turn on flash, do not connect to camera
Wait until flash is ready
Get a small wire with insulation and strip both ends about 1/8".
With one end of the bare wire lead, touch/hold CENTER TIP
Contact(silver pin from flash).
Make sure flash head is not pointing at your face.
With other end touch bare wire to OUTSIDE Contact (silver on
outside of hot shoe that rides into camera hot shoe rails-this is ground).
Flash should fires, gets a flash out of the flash tube.
If not, you have flash problems.
You most likely hurt the flash by using the dome filter on top of flash.
Over 80% photographers are doing this way when shooting flash photography. And 95% for wedding photographers.
This will shorten the life of the flash.
Even more with that adapter parked onto the flash.
Hope they are helpful to all photographers.
Suggestions or comments,
atdlee@netzero.com
  • 216 Answers
SOURCE: flash doesn't flash
I think you've posted this problem already.
Anyway please see Jan 15, 2008 SB800 doesn't flash.
Check that first.
jerryg50
  • 1689 Answers
SOURCE: Flash not charging
It sounds like the inverter circuit or the control processor may have failed. This is normaly changed as a complete module.
Nikon, or their authorized service rep should be able to service this flash for you unless the parts are obsolete.
Jerry G.
Posted on May 17, 2008
Hello I have an sb800 nikon flash (4 years old) that has just started to act up....seems as my shoot goes on the flash seems to get very warm and wont always fire... Im using energizer rechargeable 2500mah...
Are you shooting those 20 pictures in rapid succession? If so the flash is saving itself by shutting down. If that is not the case, check your batteries with a battery charger to see if one may be weak causing a strain on the others. Call Nikon 1-800-645-6689
Aug 26, 2010 | Nikon Speedlight SB-800 TTL Flash
Nikon SB 800 fires but pictures reamain dark
I have 2 SB-800s. When batteries leaked in one Nikon took forever to fix it, so they eventually sent me a refurb. Then they sent my original back. Which was great, until recently it developed this problem.
Another possibly related side effect is the modeling flash does not burst -- it only fires a single (very bright) flash.
The capacitor argument sounds likely. Coincidentally I also had a problem where the flash would fire sporadically -- but that was due to scuz buildup on the contacts.
Sorry I don't have a real solution for you.
May 27, 2009 | Nikon Speedlight SB-800 TTL Flash
I would like a dvd for the using of the Nikon SB800 flash
Blue Crane Digital DVD: Understanding the Nikon Flash SB800 and SB600
  • Mfr#
  • BC202
  • B&H# BLDVDNFSB800
THIS SHOULD HELP YOU
BERRIE SMITH CAMERA REPAIR
770-312-0719
bbmw@bellsouth.net
Feb 14, 2009 | Nikon Speedlight SB-800 TTL Flash
Nikon D3 and SB800 flash problem
The Sb800 and the Sb900 is compatible . Can you tell me more of what the problem is .
There is no frim ware for the flash . The NIKON SB 900 FLASH SHOE IS THICKER AND MAKES BETTER CONTACT . THE NIKON SB800 SHOE IS LOOSER AND NEEDS TO BE ADJUSTED
Nov 23, 2008 | Nikon Speedlight SB-800 TTL Flash
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
Berrie Smith Camera Repair
bbmw@bellsouth.net
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Flash doesn't flash
Check that first.
Jan 15, 2008 | Nikon Speedlight SB-800 TTL Flash
SB800
When you attach the flas to the camera can exidentli fire. This is normal, and manufacturer recomendation, turn off the flas unit before attach or deattach, prevent this fireing. Fireing when you turn the flashead is not normal. Probably the mounting foot of the flash unit can move in the hotshoe, breaking connections between the connector pins, causing exidental fiering. Always lock the locking lever of the flas, wich can prevent this unwanted movement. Also chek the hotshoe on the camera, wich should to have a "leaf spring" keeping the flash unit steady.
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
SB800 under exposure
Hi Stew,
Do the following:
ISO: 400
Shooting Mode: RAW or high JPEG
White Balance: Flash
Camera Mode: M
Camera Shutter: 30 or lower
Lens Aperture: 2.8
Flash Mode: A at 2.8
Flash: Wait until flash fully charged
Now, it's magic!
Send me some money for this tips when you make more money and produces great exposures:-)
Now, you're the top photographer in the town.
You can set ISO to 800 if you are not printing bigger than 8 X10.
Hope above are helpful to you and all photographers.
Alexander
atdlee@netzero.com
Nov 22, 2007 | Nikon Speedlight SB-800 TTL Flash
SB800 firing but not syncing??
I had that same problem with the SB600 and the SB 800. Solutions; get a new one. After about a year of usage the sb600 started giving me that problem. It flashes but it does not sync. It still works as a remote unit, but not mounted on the camera. The SB800 just went to a coma last weekend. No sync at all, not even as remote unit, no strobe function, just a bright flash, when triggering the test button with new fresh batteries, it flashes at max power once and takes around 7 seconds to recycle. No multiple flashes at all. I had to buy a new one.
Jan 09, 2007 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
124 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
