Question about Whirlpool Dryers
Whirlpool awz 7303 - drum spins intermittently
  • 481 Answers
Sounds like the belt is going bad or something is jamming the drum up like a bad roller.
Posted on Jun 29, 2008
Whirlpool awz 412 not spinning
You will need to replace the motor control board. It is malfunctioning on the high speed control.
Apr 24, 2012 | Whirlpool AWZ412 Front Load Washer
My drier model no awz 7303 does not heat up
I'd check both legs of power at the plug to make sure you have all power needed.(check voltage)
My next suspect would be the element. (check continuity)
Jul 20, 2011 | Whirlpool Dryers
My awz 7303 is not getting hot there is no power to the overheats or the heater element from the timer .is there anything other than a faulty timer that can cause this
First, check the outlet for 240 VAC. Try flipping the circuit breaker off, then on, a couple times, very deliberately. If you have the correct voltage at the outlet, check the connection from the cord to the dryer.If you have the correct voltage going to the dryer, you probably have either a timer problem, or one r more of the thermostats is open.
Jan 05, 2011 | Whirlpool Dryers
Whirlpool awz 7303 dryer will not heat
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Whirlpool Dryers
My whirlpool awz 7303 is very noisy. i think it is something to do with the drum going round. could the belt need tightening?
If your dryer is noisy, check these: Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing assembly does not fail often in this type of dryer. There are videos of the testing and replacing of these parts at http://appliancehelponline.com/dryerrollervideo.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there. All parts come with installation instructions. Not all models are available.
Sep 13, 2010 | Whirlpool AWZ7303 Electric Dryer
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Open Questions:
Dryers Logo
137 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
