Question about Sony Ericsson W700i Cellular Phone
Theme was not running - Sony Ericsson W700i Cellular Phone
    Brigadier General:
  • 7,752 Answers
Master reset the phone and test it again.
Posted on Aug 24, 2008
The text on my pc keeps going blue, how can I stop it?
Windows allows you to change the themes of your computer. This includes the wallpaper, the screensaver when your computer is idle, any noises it makes, and even the color of the toolbars and windows. Sometimes, however, when you restart your computer, the theme will revert back to the Windows default theme, which is called Aero. This can be because you have not disabled Aero, because your performance settings are using too much energy, or because your screen resolution is too high or low for the theme you are using.
Screen Resolution b> The higher your screen resolution, the sharper the images and text will appear. Sometimes, however, the of the wallpaper for the theme is not the same as the screen resolution. This can cause your theme to revert back to the default. To fix this, click the "Start" button. Then click "Control Panel." In the "Control Panel" window click "Adjust Screen Resolution" under "Appearance and Personalization." Select the resolution that is the same as your wallpaper. b> Performance Settings b> If your computer is running on high performance settings, your computer's energy will be used quickly and Windows may automatically change the screen saver to keep the energy from running to low. To change your performance settings, open the "Control Panel" and click "System and Security." Then click "Change Battery Settings" under "Power Options" and select "Power Saver" or "Balance." b> Disable Aero b> Aero is the default theme setting for Windows Vista and Windows 7. If you try to change your theme and it reverts back to Aero, it is because Aero is still not disabled. To disable Aero, right-click on your desktop and click "Personalize." A window of all the themes on your computer will open. You will see "My Themes," which are any themes you have created, and "Aero Themes" under it. To disable Aero, click "Save Theme" under "My Themes" to make your current settings default, or select one of the themes under "My Themes." This will make that theme the default. b> Troubleshooter b> If you still cannot figure out why Windows changes the theme back to the default after restarting, you can use Windows's built-in troubleshooter. The troubleshooter will find the source of the problem and automatically fix it for you. To use the troubleshooter for your theme, open the "Control Panel" and click "System and Security." Then click "Troubleshoot Common Problems." Under "Action Center," select "Appearance and Personalization." The troubleshooter will run. When you restart after it completes its action, your theme should stay the same. Hope this helps.
b>
Dec 15, 2012 | Computers & Internet
Tip
Changing themes on Windows XP.
So, here we have a simple guide on how to change your normal windows look and how to install a custom theme which you will find many online.
Here is our original windows xp themed start menu and desktop.
First to install a new theme you first have to obtain one, here are a few
After you have downloaded the zip file containing the theme. Double click on the file to open it.
Now, this may look different on your pc, it depends if you have installed a program to extract zip files. If you are familiar with zip files etc just extract the files and run the setup to install the theme.
Inside the zip file you will find the following
Double click on the setup file to install the theme.
you may get a pop-up asking for you to extract all, run or cancel, click on run if you do. if asked again, click run again.
Basically install the theme just by clicking next next next and finally finish.
Once you have installed the theme, right click on your desktop background and select properties.
On the properties / theme page, click open the list of themes and select Royale from the list, then apply and OK.
And here is the new theme we downloaded:
You can obtain different themes from all over the net, I would suggest you go with the site linked here, scan the files for viruses before installing. Good luck and thanks for reading.
on Jan 23, 2010 | Computers & Internet
How can i install themes for my lg Kp500 cookie because i want to change it
There are 2 location were you can store the themes on your phone, either on phone memory or in memory card.
If the theme application comes from the computer, you need to transfer it on your memory card by using a multi media card reader, you can make a folder were you can place the themes or just put in on the root directory of the memory card,now from your phone, locate the file manager by going to your phone settings. just run it and follow some instruction,then after the process is done, go to theme settings and run the theme application you download.
If the theme application directly download on your phone via bluetooth or GPRS, just locate the phone memory on the file manager and do the same way.
You can download themes from this free site : KP500 THEMES
Hoping this method helps you.Good Day..
Jul 05, 2011 | LG KP500 Cookie
Can't apply any original theme on XP
if you have a xp cd, do a fix operation of the systeme.
1- insert the cd
2- chose repaire option "not new install"!!!
Sep 09, 2009 | Microsoft Windows XP Professional SP3 Full...
Running Clock type theme is not working in my mobile
hai Dear ,
the themes format type was not support. your mobile can not support this themes.
so you can download themes to internet threw.
Mar 08, 2009 | Sony Ericsson K550i Cellular Phone
How do I use a theme downloaded ?
Check Local Disk C:
WINDOWS
Resources
Themes
Nate P.
Jan 21, 2009 | Microsoft Windows Vista Ultimate Edition
Run the application for theme
to change themes you should download theme switcher software for assit (varun.sonu143yk@gmail.com)
Nov 20, 2008 | HP iPAQ h6315/h6365 Pocket PC
Animated wallpaper
you can't install a running animated wallpaper in my nokia n72. don't waste ur time
Sep 25, 2008 | Nokia N72 Cellular Phone
How to download psp themes??
There are actually a lot of themes running around the internet now...just type in your search bar PSP themes. How, for the location of the themes, just put it in your themes folder on the memory card of your PSP>>ms0:\PSP\THEME (ms0: meaning the root directory of your memory card)
Aug 03, 2008 | Sony PlayStation Portable (PSP) Console
I can't apply vista themes which i have download from internat as i have window vista home premium
The error you are getting says that the theme can not be loaded because theme service is not running, so to start the themes service press WIN+R on your keyboard, type "services.msc" in the run box (without commas) and from the list that opens, find the theme service and start/enable it.
Oct 19, 2007 | Microsoft Windows Vista Ultimate Edition
Sony Ericsson W700i Cellular Phone Logo
24 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
