Mackie SWA 1501 limiting problems, I seem to be getting the limit switch on the back of the mackie bass bin coming on constant.The levels of the mixer are fine,could there be a problem with mains source? Cheers!!
  • 682 Answers
Yes it maybe mains proplem and you must check it with voltmeter to solve your problem
Posted on Jun 28, 2008
How to open my mackie swa 1501 subwoofer to change the fuse?
Service manual is available for free from it contains disassembly instructions. If you change the fuse and it blows again, then your amp will need service.
Oct 06, 2014 | Mackie SWA1501 Subwoofer
My mackie swa 1501 when you plug in no power checked the outlet their is power checked power cord good. what can i do
There are many possibilities, the switch, motherboard, electronics etc. If you are a DIY kind of person and you want to try trouble shooting yourself, you need tools. Better still, take it to a service person/ outlet to proper checks.
Why does my mackie swa 1501 sound keeps cutting in and out
So it's heavy? .... i wanna know exactly what happens . You turn it on and turn on the volume, pls tell mecwhat exactly happens and when with which freq
thx rich
Jun 17, 2014 | Mackie SWA1501 Subwoofer
Mackie sub swa 1501 no LED no output but light on board appears to be on
los transistores de salida estan en corto 2sa1943 y 2sc5200 reviisa los drivers tip 122 y los irf
Feb 18, 2012 | Mackie SWA1501 Subwoofer
Blowm fuse
for 110V supply use at least 8Amp fuse but for 220V supply 4amp will do.
Mar 12, 2010 | Mackie SWA1501 Subwoofer
The Amp on Mackie SWA 1501 sparked and burned today
I don't think the amps are available from Mackie any more. You can have it fixed:
Nov 26, 2009 | Mackie SWA1501 Subwoofer
Any idea why my Mackie swa1501 bass bin has blown 2 speakers in the last 3 months? Bass Drum is the heaviest instrument going through it, but I never let it clip, I also run a fan on it which keeps it...
does your swa1501 get hot just being switched on ?
sounds like your output transistors breaking down or your dc to dc rectifier is shorting this would dumping high voltage to the speaker. I guess your speaker coil is burnt . check Q4,Q5,Q7,Q12.Q14,Q15,Q17 and Q18 these are all mosfet transistors that commonly break down..
Oct 01, 2009 | Mackie SWA1501 Subwoofer
Mackie swa 1801 power amp R7 100 ohm resistor smokes when powered up..
You likely have other parts blown as well, but Q3 (MJE15033) AND/OR r8 (1 OHM/0.5 Watt) are blown. I suspect that Q3 has a base-collector short and you will find several of the output transistors are fried as well Q4, Q5, Q15, Q16. I suspect that the Zeners D14, D25 may be blown.
When restarting this, put a 100 Watt lampin series with teh 120 volt power to limit current and avoid destroying freshly repaired parts due to a few bad ones not found.
Aug 17, 2009 | Mackie SWA1801 Subwoofer
I have a pair of mackie srm 450 and one swa 1501 the bass output in one of the 450s has no sound. i hear sound only from the high frequency part of the speaker
you have one of two problems.1) the woofer is blown(most likely) or 2) the crossover is fried(rare). Take the woofer out and press on the speaker cone(softly). If there is a scratchy feeling when you move it or if it doesn't move at all, you'll either need a new woofer, or get that one reconed.
good luck.
Dec 04, 2008 | Mackie SWA1501 Subwoofer
91 people viewed this question
