HP w1907 LCD Monitor Logo
Posted on Dec 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an hp 1502 LCD monitor. a weak before it start problem, as when i on it the screen goes blink white just after having a glimpse of the desktop view and when i do on and off it for several times it goes right but i faced the same problem each time when on it.... whats the problem within...
Anonymous
Level 3:
  • Master 1,833 Answers
  • Posted on Dec 07, 2010
Anonymous
Master
Level 3:
Answers
1833
Questions
0
Helped
554888
Points
4774
This is the inverter board problem. There is an inverter board inside LCD monitor. Most probably the capacitor has gone bad. There is no way you can fix it (unless you are a qualified technician). Please take help of HP service center or call a person who repairs LCD monitors.
My hp 1502 lcd monitor only shows a white screen
If you don't use an identical monitors, then they may not work if your video card can not handle them. The "check video cable" it means the monitor does not get a signal, and it does not mean that the monitor is a problematic monitor. You can test this monitor as a single monitor (and try to connect it using first video port, and then move it to the second video port).
When i supply power in my hp 1502 desktop and connect it with cpu than my desktop scree only show its going to sleep
1.check with a other monitor.
2.check the cabels should be seated tight.also the videocard should be seated tight.
3.the videocard or the monitor can be brooken check with a new or other monitor first.
Hp monitor vga cable wiring solution
Hi,Sir/ i have lcd monitor Hp-L1502 its on position wen i start lcd without vga cable to frount lokation is red+green+blue colours step by step fliker&i can fix new vga cable.whats sulution?
1helpful
2answers
For some reason my screen is now upside down, what do i need to press to correct this problem, thanks
If you can't right click on the desktop to change the orientation. Then hold down the ctrl + Alt + press one of the arrow keys till the screen gets back to normal.
Compaq 610 when i start vdu is white screen and
hI,
if the screen is completely white the problem could be a bad LCD cable. To cross check if the problem with the LCD or the motherboard. Connect an external monitor to the laptop. Tap the Fn + F8 key together to get the display to toggle to the external monitor if the display comes on the external monitor without any problems the problem is with the LCD and you would have to take the laptop for repairs.
Thanks for using Fixya
Proton
HP L1906 flat monitor
why not test the monitor on another PC
works there good.,
if not the monitor is bad.
can be monitor bad, cables bad, power pack if fitted bad.
test it on another PC.
win
if bad monitor start a post how to fix a bad monitor (endless answers)
W19-1 turning white, with small breaks of black screen
there is an issue with the HP monitor which you using you need to replace it
3helpful
My hp 1502 has a problem.screen is white,but LED not lighted.
You need to replace the bad electrolytic capacitors inside.
Monitor Mike
Hp F1703 LCD Monitor gray/white Screen
Hi...there,
It's seems you got a busted AD board... Need to replaced a new one or replaced a new bios...
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
