Question about Sewing Machines
Necchi 3537 ~ Stop Motion Knob Won't Turn
I bought my machine many years ago and have not used it much. I took it out and tried to wind a bobbin, but I can't seem to unloosen the stop motion knob in order for the bobbin to fill.
Any ideas please?
  • dmyers01 Jun 28, 2008
    Thank you very very much for your help. This a.m. early, I took the covers off and noticed there was rust, so I got a big pair of pliers and turned the stop motion knob and it moved. Once I knew it was rust, I assumed it just needed loosened up, so I became brave and got the big pliers!
    Thanks again for your help !
4 Suggested Answers
  • 323 Answers
SOURCE: Stop Motion Knob
Dear Jim,
I'm sure you have a pair of Channel lock pliers around.Place a fairly thick piece of fabric around the inner knob to keep from scratching it. Grasp it with the pliers while holding the handwheel and turn it to the left. IF you can't hold the wheel to keep it from slipping, place a screwdriver or something else under the needle set screw area, turn the wheel until the set screw is resting against the set screw and then turn the inner knob with the pliers.
Posted on Sep 03, 2008
  • 980 Answers
SOURCE: took stop motion knob off how do the pieces go
You should have a three pronged washer, put that on first anyway round, then put the stop motion wheel on and tighten fineger tight, tighten the small screw that should be on the stop motion wheel and tighten a bit more, if it does not tighten up take the stop motion wheel off and put the three pronged washer in a different position.
Posted on Jul 18, 2010
  • 92 Answers
SOURCE: I cannot loosen stop motion
Sometimes the knob locks so tight it requires a good strong beefy man to loosen it. Turn it counter clockwise!! You can also wind without loosening the knob, just MAKE SURE to unthread the machine and to sew for winding only. It works for all industrial machines, without loosening the knob.
Posted on Jan 15, 2011
I have a Necchi 3101FA. I am trying to figure out how to release the stop motion knob so that the needle won't run while I am trying to thread the bobbin. Does anyone have any idea?
the hand wheel is a 2 part device hold the outer wheel and release the inner part by turning it toward you . wen done winding bobbin retighten the wheels together .
Aug 26, 2015 | Necchi 3101 Mechanical Sewing Machine
Why won't the motion stop knob will not move?
Look carefully for thread caught around and under the knob. If you can't get it to turn and find no reason why it won't, you can probably delay fixing it until the next time it's due for its yearly "tuneup" (COA, clean/oil/lubricate) by taking the needle out before you wind a bobbin.
Jun 02, 2014 | Husqvarna Husky 145
How to free motion sew on Necchi 3537
Use the darning foot or the free motion foot, drop or cover your feed dogs and set your width and length to zero. Then test the tension. With these changes, sometimes the tension is off.
Apr 14, 2014 | Necchi Sewing Machines
Necchi model 3537 won't pick up bobbin thread has a list on their site with helpful free tips. I found this site for you I think will get you on your way. Hope this helps.
Apr 03, 2012 | Necchi 3537 Mechanical Sewing Machine
I have inherited a Necchi 537FA. When I wind a bobbin I loosen the stop motion wheel, but the sewing mecfhanism doesn't disconnect, it still "sews" through the entire bobbin winding procedure! ...
Its been idle for too long and needs a good service. Try and trickle some oil behind the stop motion wheel. But what it actually needs is to have the wheel removed and then apply oil to the shaft. Careful when you start again as oil will fly out from the wheel so mind your drapes and wall decor.
Dec 12, 2010 | Necchi 3537 Mechanical Sewing Machine
The knob on wheel stuck.
Remove the needle, and place a screwdriver or something like it under the needle bar to keep the wheel from turning.
Wrap the knob in some type of fabric to keep it from being marred.
Using channel locks or water pump pliers, grasp the knob and turn it to the left. It should come loose. Once it is loosened, try it 2 or 3 times to make sure it works as it should.
Wind the bobbin, insert a new needle and have fun again.
Dec 29, 2008 | Necchi 3537 Mechanical Sewing Machine
Machine stops after 2-3 stitches
open your bobbin case and un jam it thread wound around the center
Dec 02, 2008 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
166 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
