Question about Casio Exilim EX-Z55 Digital Camera
Display goes blank
When I turn the camera on in picture taking mode the display shows for no more than 2 or 3 seconds then goes off. You can switch to displaying previous shots and the battery strength is fine. You can also take pictures - you just can't see what you're taking when you are taking the shot.
  • MMdigital Nov 09, 2008
    Exactly the same as described above. I'll try the fix recommended. M
  • Anonymous Dec 30, 2008
    my screen goes to black, but all the other option screens work well...only picture taking mode goes to black. Camera needs to be restarted and i have a moment to snap a pic...
I tried Solution #1 (twice) with no luck. But, when drilling down thru the options in "menu" I found one that said "reset" and tried that. Voila! Back in business. Display no longer blanks in 1-2 seconds. Don't know if this only works after reformatting internal memory or not. So, if no luck with "reset" try to reformat then reset.
Posted on Jan 16, 2009
  • 374 Answers
It sounds like your lcd is going out. Sometimes it will do that when you switch to picture taking mode. Don't understand why. Try taking your mem card out. If you have pics on your internal mem transfer them to ur computer. Format your internal memory and then try it again. If it still does it then you're going to have to send it in.
Posted on Jul 14, 2008
Pics are blank in viewer
there are many reasons that no picture is displayed:
1. there is no picture in the first place. (camera lens closed when picture was taken)
2. you are not on display mode (toggle to display mode not "take picture" or capture mode)
3. defective memory card.
4. you are on display mode but on another sub-mode which does not display pics... (toggle to display, details, etc...)
Aug 24, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Describe how to use the self timer on the samsung S830 digital camera
Make sure you're in a recording mode other than VOICE.
Press the Self-Timer button (right button) until the display shows the desired mode. Your choices are 10-second mode (the camera takes a picture ten seconds after you press the shutter button), 2-second mode (the camera takes a picture two seconds after you press the shutter button), and Double-self-timer (the camera takes a picture ten seconds after you press the shutter button, then takes another two seconds later).
You can cancel the self-timer mode by pressing the Self-Timer button again.
The 10-second mode allows you to run back for a group picture. The 2-second mode is useful when you want to take a picture without fear of camera shake; simply place the camera on a steady support such as a tripod. The Double mode increases the chances of getting a picture with everybody's eyes open.
Jan 11, 2010 | Samsung S830 Digital Camera
Camera switching on ok but lcd sceen blank
Your problem can be the result of a number of causes - two common ones I will list here.
Most common cause would be a failed printed connecting cable between the main camera electronics and the flip out display panel. This special cable passes through the display hinge and is sometimes subject to failure.
A second possibility is a faulty display backlight.
You can check that the camera is still producing video output by using the AV cables conected to a TV display with the camera set to CAMERA mode.
I trust that this information is of assistance. RHN
Jan 02, 2010 | Sony Video Cameras
The screen on my camera will not display anything at all. The camera appears to turn on, but the screen is blank. Even when I switch it from one mode to another, there is nothing displayed on the screen
Have you tried taking pictures with it? Do the pictures show up when taken? If so, then it's likely that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Oct 26, 2009 | Canon PowerShot SD600 Digital Camera
I have no LCD screen when my E300 is turned on, it stays blank until I take a shot, the LCD screen shows this shot for a couple of seconds and then blanks again.I can't seem to find the problem in the...
Have you tried pressing the 'INFO' button? This little button will toggle between camera info on display/no info on display (when the display isn't in use to display pictures).
Oct 19, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
Unable to take photos
See this link. The symptoms you describe indicate your CCD sensor is bad.
Aug 18, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
Jul 07, 2009 | Canon PowerShot SD600 Digital Camera
Blank View Screen
Press DISP. button, and repeat untill the display shows up
Jun 02, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Casio Exilim EX-Z55 Digital Camera Logo
122 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
