Question about Konica Minolta magicolor 2400 Laser Printer
Minolta 2400W - Put cyan / black toner
I have disabled most pop-ups in order to extend toner usability. Atfer a recent reboot, it has repeatedly asked for either cyan or black toner cartidges to be installed, but I know they ar not empty. I have cleaned eveything down (several times), removed / reinstalled the drivers. No good.
Is there a 'factory reset' fix??
Thanks,
Tony
    Champion:
  • 214 Answers
Hey, the problem is that toner cartridge reading chip is dirty.
take out Pc drum and remove all toners, clean toner chips with alcohol. then locate a 3 pin reading chip under the toner rack left side and use pressure air to clean it. reinstall everything. if its not helping, replace the chip, its not expencive
Posted on Jul 01, 2008
When I start up printer after it rotates the toner cartridges the error light comes on and cannot be cleared . On my Windows computer it says there is no cyan toner cartridge. There is, of course.
Does it say Image Cartridge or toner. Is the cartridge third party if so replace with a real Minolta cart the machine do know info on the chip on the cartridge and reject them sometimes
Feb 19, 2011 | Minolta magicolor 2400W Laser Printer
Minolta 2400W errors
GO and get 4 Konicminolta image units one for each color and replace them do not use third party. NEVER ever use a vacuum cleaner the static electricity can cause sensors to go bad !!!!!!!!!!!! might have destroyed the chips on the image units SO recommend get all new hopefully you did not destroy the control board with static electricity
Apr 27, 2010 | Minolta magicolor 2400W Laser Printer
KONICA MINOLTA 2430 DL - BLACK NOT INSTALLED, CYAN NOT INSTALLED
Unfortuanately, the only solution that I know of is to purchase new chips ($15 ea.) There are multiple websites that sell these. I had the same problem and have resolved it in this mannor. I tells the printer that it is a new toner cartridge. There is another post in 'fixya' that explains howt to disable the 'reading' capabilities of those chips. You have to go into your status display box, printer, mode setting, then uncheck auto toner replace and restart printer. It is supoose to do away with the 'reading'. I tried it BEFORE replacing my toner and it didn't work. You have to replace it first, then follow those steps.
Jun 15, 2009 | Konica Minolta magicolor 2400 Laser...
How to remove the toner cartridges
Close the cover to the machine and make sure you aren't getting any other error messages other than the toner. When the printer is at the ready state press the rotate toner button. You should hear the printer rotate the toner and then the light over the cyan cartridge will come on. Keep pressing the rotate toner button until you get to the color you want to replace. Open the top cover and front door where the KM logo is. You should see the cyan cartridge in place. Pull the cyan tab back toward you. The front part of the toner should release. Now pull the tab and the toner straight up and out of the printer. If you are having problems getting the toner out it is probably not in the correct position. There is a slot on either side of the printer that he back end of the toner cartridge needs to be in before the toner will come out.
Jul 10, 2008 | Minolta magicolor 2400W Laser Printer
Toner Not Installed - After replace black
pleas clean toner chip reader, remove pc drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it. if the new BK toner is not original, it will say only not genuine toner but will print.
Jun 23, 2008 | Konica Minolta magicolor 2400 Laser...
Rotate Toner Button Does not Work
How do you change four toner cartridges-Minolta 2400w Printer?
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Error flashing, Status 'Put Cyan Toner' - but toner showing 100%
I think someone touched on this solution briefly, but here is how you fix the problem.
Clean the 3 copper contacts on on the green chip with an eraser or rubbing alcohol. The chip is on the right side of the cartridge. You will probably see black lines on the contacts. This will fix the issue about 90% of the time.
If it doesn't work you want to clean the chip reader. This is the switch that CCSStech was talking about. It also sits on the right side of the printer almost under the toner cartridges and has three prongs sticking up. Clean those prongs with alcohol. If that doesn't work replace the switch. If you are using refilled cartridges, the chip on those sometimes doesn't work. In that case have the manufacture of the refill replace the toner for you.
Feb 21, 2008 | Minolta magicolor 2400W Laser Printer
Installing new black print cartridge
Manually Removing Toner for magicolor 2400W
1.  Hold down the Cancel button for 10 seconds or longer.
2.  With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3.  When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4.  Then hold down the Rotate Toner button again for another 10 seconds or longer.
5.  The Cyan toner cartridge moves into the proper position, so it can be removed.
6.  Remove and/or replace the Toner Cartridge if necessary.
7.  Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
Oct 21, 2007 | Minolta magicolor 2400W Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
363 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
