Question about Tomtom GO 910 GPS Receiver
Tomtom910 will not come on even though it been on charger ie,car all so when connected to p.c
    Brigadier General:
  • 6,966 Answers
Initially, try to do a soft reset by using a blunt/dull pin and hold the soft reset button for about 5 to 10 seconds (the reset is not on the face, but in the hole at back where the unit connects to the base; opposite side of the gold circle, up just a little from the green strip). It would seem that the battery shuts down if it's overcharged, so if you charge it for more than a few hours it might not turn back on again.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 28, 2008
  • Louie  Role
    Louie Role Jun 28, 2008
    Hi again,
    Should that not do the trick, you may have to do a a full format and re-install. This link would give you an idea of how it is done or you may opt for a full factory re-install at any Tomtom Service Centers.
    President:
  • 2,712 Answers
Can you explain a bit more in detail?
  • Swilin Sampson
    Swilin Sampson Jun 28, 2008
    Have you tried connecting it to direct source of power, example the mains via an adapter?
  • Swilin Sampson
    Try shining a torch onto the screen when its connected to any power source..including car charger. If you see a faint outline of the intended screen, it could be that the screen is damaged (backlight) and will have to be replaced by an authorised service center.
Makita DC1804T charger
No, batteries age even if not being used.
Mar 28, 2014 | Makita Univ Volt Charger
My garmin was working and the other day i plug it in the car charger in and now my garmin will not work while it is on the charger. If I take it off the charger it will work but not on the charger. what...
Does it show a picture of a satnav connected to a computer when plugged into the car charger? Sometimes this happens because the charger plug is not fully pushed into the back of the satnav even though it feels like it is. Pushing it in further may solve the problem.
Jul 14, 2011 | Garmin nuvi 250W GPS Receiver
Earlier my laptop shut down with no warning even though the charger was all connected and plugged in. now even though the charger is plugged in everytime i try to turn it back on the needs to be charged...
This could be caused by several things, but try the obvious first. I just bought a brand new power supply, and in less than a week the customer called and said it stopped working. I suggested she take the cord from the old charger and try it - it worked - the brand new cord lasted less than a week. The other thing that could cause this is a bad connection on the end of the power supply, going into the computer. It could even be a bad power supply.The last thing I can think of is a bad battery that won't hold a charge.
Aug 12, 2010 | HP Pavilion dv4000 Notebook
Can't connect to the internet
Alright one get THE F**K off IE download chrome or safari even firefox IE is **** because of all security threats
Apr 02, 2010 | Toshiba Satellite A135-S2276 Notebook
Tomtom910 not holding charge or charge properly
Looks like the battery needs replaced. Go to: http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
This site will give yo step by step how to change the battery. Good luck!!!
Oct 03, 2009 | Tomtom GO 910 GPS Receiver
Tomtom910 won't turn on. I replaced the battery, charged it and now it won't turn on.
Try doing a reset. The reset hole is on the bottom of the TT 910. Use a paperclip to do the reset. Gently push the paperclip into the hole until you feel a click the hold it for 30 seconds. That should do the trick, unless the unit is not actually charging. The green light will come on but not charge because of a bad connection on the motherboard on the negative side.
Jun 20, 2009 | Tomtom GO 910 GPS Receiver
Phone charger problem
You should use a genuine sagem charger
Nov 27, 2008 | Sagem My501X Cellular Phone
TomTom910 not charging
This is a common problem with the 910. Try putting an obstacle in the way of the wire to keep it on. Better still is to not use the home dock at all. Just plug the home charger in to the windscreen mount (device connected of course!) and charge it that way. You get a better charge and it will stay on.
Nov 16, 2008 | Tomtom GO 910
Tomtom910
This is called "auto zoom", look through the menus to turn on/off.
Nov 08, 2008 | GPS
Tomtom GO 910 GPS Receiver Logo
77 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
