Question about Microsoft Windows Vista Ultimate Edition
Vista tranformation pack 8.0.1 installation error
I've tried the installation in the safe mode but it didn't worked & got again with the same error window. please tell me the solution to install it, i'm using
windows xp sp2, 256 ram, P4 1.80 ghz............................
my id is: time_perfect@yahoo.co.in
IF U HAVE ADDITIONAL THEMES OR SCREEN SAVER INSTALLED IN UR COMPUTER FIRST UNINSTALL THEM AND THEN TRY TO INSTALL VISTA TRANSFORMATION PACK
Posted on Jun 30, 2008
Vista boots just Black screen with cursor even in safe mode
Yes, this is a known issue with Vista. You need to back-up your data, format your hard drive and re-install Vista from the beginning.
There is really no use trying to repair it: it is damaged.
After you re-install Vista, do not forget to install service packs from microsoft.com.
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
Cannot install vista tranformation pack 9.0.1
Run antivirus on this machine clear out any viruses that may be infecting this file then proceed to install, if this information help you please rate it Fixya, thanks
Apr 26, 2009 | Microsoft Windows XP Professional
Restarts computer in loop at 5-8 minutes of boot
Please try install XP SP3 in safe mode. Then check whether you have the latest Graphics Card Driver. It seems like some driver issue as it reboots only in Normal mode. Since safe mode runs on minimalset of hardware drivers.
Secondly, there may be a corrupt file that caused reboot. Spend a night and schedule bad sector check - Right click on system drive, Tools tab, Error Checking -> Check Now, tick both boxes then Start. It will schedule scan on next reboot. Then reboot to confirm it starts checking HD.
Apr 24, 2009 | Microsoft Windows XP Professional With...
Error code on dell laptop
There are two options you can try:
First boot up and hit F8 to put it in Safe Mode. Then go into your Control Panel>Add/Remove programs and uninstall Service Pack 1. Reboot and see if that works. If not try this:
Boot up into Safe Mode again by hitting F8 when it starts up. Click on Start>Programs>Accessories>System>System Restore (It may be a little diff but that is close). Click on System Restore and walk thru the Wizard, this will restore your computer to an earlier date before you installed Service Pack 1. Good Luck.
Dec 22, 2008 | Dell Inspiron 1501 Notebook
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
Problem in vista tranformation pack
try to reboot the machine after it boots then click on start button then all programs-accessories-system tools then click on system repair it will repair your comuter after then just reboot the computer.
Aug 19, 2008 | Microsoft Windows Vista Ultimate Edition
I have Windows Vista installed on my laptop. I install all the automatic updates. Recently Vista downloaded Service Pack 1 and I installed it. After the installation my laptop stopped working. I can...
Your problem: "I have Windows Vista installed on my laptop."
Unfortunately, as with a lot of MS service packs, they can crash some computers. You need your windows vista disk and, booting from it, you can select repair your vista installation. This should take care of the problem. Then don't update to sp1 for a few months.
Jul 05, 2008 | Acer Computers & Internet
Acer Aspire 5630
Seems like your VISTA upgrade didn't sucessfully upgrade itself from XP to VISTA. Seems like M$ update program detects your OS as XP and tries to install the SP3 for XP. VISTA only has SP1 released. Its currently stuck in a loop that it doesn't know what to do. Restart your laptop into safe mode by pressing F8 before the VISTA loading page comes up and go to Safe mode and backup your data and use the ACER RESTORE CD OR ACER RESTORE METHOD to help you reload your system back to factory defaults then upgrade back to vista without install any updates or connecting it to the internet.
This is my best solution to get you out of this weird and unusual situation.
Jun 30, 2008 | Acer Ferrari 4000 Notebook
Vista Transformation Pack 8.0.1 screen shot
I used this software and it is working fine with me . it is working with Vista and XP. I think there is some memory problem . Give me some information about your motherboard , ram ,oprating system .
Please rate me .
May 05, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
