Question about HP PSC 1315 All-In-One InkJet Printer
Only prints in colour
My printer only prints using the colour cartridge - I keep running out of cartridges - how do I select the black & white cartridge?
    Genius:
  • 2,785 Answers
There should be a setting in the printer as well as in the printer printing dialog box
Posted on Jun 28, 2008
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
Printer is not printing black but in a pinkish color
Most printers use the colour cartridge to make black, instead of the black cartridge. When you go to print a black and white document, on the box where you choose the number of pages to print, click properties, and locate the colour settings. There will be two options: Colour/Black and White-with a sub option of high quality or black only. Select Black only. The printer will now only use the black ink.
Apr 14, 2010 | HP J3680 Officejet All In One Printer
I recently replaced the black ink cartridge and do not wish to use the colour cartridge. However, the printer still keeps flashing the critically low level of my colour cartridge and does not print.How can...
Many printers always use a small amount of each color even if you are only printing black, to prevent the color nozzles from drying out and getting clogged (and, it forces you to buy more ink, which is a profit center for printer manufacturers)
For this reason, some printers will not work if ANY of the cartridges are empty.
It should work again if you replace the color cartridge. Make sure to select "black ink only" or the option to print in black and white or grayscale to minimize color ink usage. It may still use a little, but that's OK.
Apr 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Can't print color only black and white
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY. hope this helps , AJ
May 18, 2009 | Dell 966 All-In-One InkJet Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Print black & white?
Your printer will keep using the color cartridges to keep the printing head working even if you don't print in color. If you need to print only in greyscale, buy a cheap HP printer (Printer only, not a PSC) and remove the color cartridge.
Apr 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
Ben Johnson
