Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Scrambled picture TV was working fine. Went to turn it on and picture comes on, but is scrambled. Sound and programing is coming through. The screen is black with small white dots on it and the rest is horizontal lines that are fuzzy. The picture is not clear enough to be seen. Changing channels makes no difference. You can hear the channel change, but same picture. I changed out the cap's about 8 months ago and it has been working fine since. Any idea's???
  • Mitsubishi Master
  • 8,617 Answers
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Posted on Jun 28, 2008
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
My ps3 system will turn on, get the green light, but don't get any sound or picture. it's not my av cord, cuz i am using my ps2 on it now. my ps3 was working just fine and then my screen just scrambled and...
Interesting problem. I recommend trying a reset of the video card. It's pretty easy, Sony has the instructions here.
Except for the scrambling and freezing, it sounds like an issue I had recently with my own system. Give this a try and please leave a comment on weather it worked or not.
Dec 14, 2010 | Sony Playstation 3 (PS3) Console
Hello, have a 32 inch flat screen sharp tv. worked fine all day sunday, went to turn it on last nite no picture only sound. noticed when tv is off and plugged into the wall and you go to turn it on, there...
It can be that it has unstable power supply or the CPU/EPROM are getting scrambled by the noise and spike in the AC line, you may try better AC line conditioner to see if it will help.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 05, 2010 | Sharp Televison & Video
TV TURNS ON HUMMING SOUND FOR ABOUT FIVE MINUTES AND GOES AWAY
go in audio section and select mono instead of stereo or sap
Sep 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
No picture just sound
Your projection tubes are messed up. It's a very expensive fix, just get a working TV off craigslist with a smashed screen and reuse your screen itself (usually 100-200$) or just toss the TV and upgrade to an LCD
Apr 29, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Sound and no picture
Hi, if your getting half a picture AND the other half is black the vertical circuit is failing, either solder is broken or vertical IC needs to be replaced, not a pricey fix, BMW Rider
Jan 04, 2008 | Sony KV-32S26 32" TV
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
147 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
