Question about Nilfisk Vacuums
Nilfisk sd4 polisher/scrubber pulling hard to one side. any ideas thanks pat
SOURCE: nilfisk advance floor scrubber vacuum problem
CAN YOU HELP? I AM LOOKING FOR A SMALL FLOOR POLISHER AND SCRUBBER FOR MY OWN USE AT HOME. i SHOULD HAV TWO 5_6" SCRUBBER PADS AND FLOOR POLISHING PADS. THANK YOU AND GOD BLEES. NORSANRAIDERS@MSN.COM LOWTON , OK
Posted on Jul 10, 2008
How do I put a new wheel on nilfisk a300
by the picture of the
nilfisk a300 replacement wheels
its a pull off clip on type design
the axle should be metal
it will need some force to remove the old wheel
may even try to break the old wheel off in pieces
Sep 07, 2016 | Nilfisk Vacuums
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
Cable will not retract
If you are having problems with a NIlfisk King cord reel it will either be that the cord is simply dislodged or the retract could be faulty. I have made a video showing how to pull it apart which could be used as a reference to diagnose the issue.
If you need a new retract we have these available online as well, the part number is 22352606 Nilfisk King Cord Rewind
Feb 18, 2012 | Nilfisk Vacuums
Nilfisk Extreme 300 does not always respond to the remote trigger on the handle
The Nilfisk X300 has a battery in the handle piece it would be worth simply replacing the battery. If that does not solve it you may need a new Nilfisk X300 Handle. It is possible that it is the receiver i teh machine but to be honest these are a pretty hard machine to work on and the circuit boards are all interconnected, this is a repair for an experienced player.
Sep 03, 2011 | Nilfisk Vacuums
Nilfisk A300 Suction problem
Mate - don't know if this will help - I had the same symptoms - saw your question through google - no answers, then I moved the red slider button on the top of the vacuum and hey presto! It has adjustable power. Man I felt like an idiot!
Jan 30, 2010 | Vacuums
My Nilfisk vacuum cleaner overheating and stopping
Its probably clogged..
Remove the hose,, straghten it out so you can look into it..
Could be clogged where the hose connects inside the unit..
Jul 26, 2009 | Vacuums
Nilfisk c120 vacuum - no power
The fuse is part of the motor so is not something that can be changed. Make sure that there isn't a break in your power lead at the plug.
Mar 15, 2009 | Vacuums
Nilfisk advance floor scrubber vacuum problem
Mar 12, 2008 | Vacuums
No power to scrubber head
Hi Dennis_b,
to continue checking that problem, please see, with an electrical screwdriver, if the machine has energy where the scrubber connects. If yes, the problem is in the scruber; if no, the problem is in the machine, where a red and a black wire makes the connection since the electrical extension to the scrubber connetion, passing thru the swich. it makes me to think in various problems. Even a broken wire can make a malfunction.
Complements
Jan 19, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
56 people viewed this question
Top Nilfisk Vacuums Experts
Jim Parker
Jim Parker
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
