Question about Hotpoint NWXR473EV Dryer
Hotpoint aquarius CTD00 dryer won't heat
The empty water light stays on and there is no heat. In one of your solutions you said to check the switch where the tank is removed from is open. Where so I find that switch because I can't see one! Thanks
  • Anonymous Oct 01, 2008
    When turning on the dryer (CTD00) the empty water light comes on and no heat is produced. The water has been emptied and filter cleaned.
  • simon31 Jan 16, 2009
    hi my hotpoint CTD00, wont drain water to the drawer, it keeps gathering at the back of the filter.
    Thank you
    Amanda
  • 3 Answers
I have just had a similar problem and fixed it today.
The "Empty Water" light was staying on and no heat was given out to dry the load.
I found it to be the float switch in the condenser unit at the back left. It had stuck with fluff and debris. I cleaned out the condenser reservoir and the polystrene float and now all is well.
To get to this unit you must first,
Take of the top and the left hand side panel.
Locate the 2 locking tabs that hold the top half of the condenser onto the back panel and release this part.
Remove this by releasing 2 further tabs that hold it to it's bottom half,
and you will see the float switch assembly on the left hand side.
Clean out the condenser reservoir of any water and aslo clean the polystyrene float, it needs to be free to slide up and down between the plastic guides.
Hope this helps.
JohnM
Posted on Aug 20, 2008
  • GERALD DAWSON
    GERALD DAWSON Dec 13, 2013
    Hi John Ihave done all that but I also removed the switch and I could have rewired it up wrongly
John2201's solution was very helpful. In addition, to his instructions would suggest to check that the water line leading from the pump up to the tray is unblocked and there is nothing in the pump. My problem was a blocked water line. Then of course clean all the crud out in the reservoir and in the condenser cavity as well.
Posted on Oct 10, 2009
  • jodysutts Sep 27, 2010
    thank you!! got it working again due to your advice! :)
3 Suggested Answers
SOURCE: hotpoint aquarius condenser dryer ctd00 - empty
The float switch within the plastic unit at base of machine has failed,shorted out Carefully prise the unit open Disconnect and identify the three tags Replace switch and attached lever Examine the insulation on the rear tags as they are very close Reinstate Red light will now extinguish pump will run when float operates hearers will come on
Posted on Nov 22, 2009
SOURCE: dryer revolves but no heat on any settings
fixed using posted advice on resetting thermostat.
Many thanks
Posted on Dec 11, 2009
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
Dryer not heating up
To be certain whether it is the element or thermostats that are faulty,you really need a test meter to check them with, as it is not obvious if they are faulty or not, simply by looking at them
Hope this helps.
Please rate my solution.
Thankyou.
Dec 21, 2009 | Hotpoint Dryers
Hotpoint aquarius condenser dryer ctd00 - empty water light will not extinguish after water has been emptied resulting in no heat
Oct 15, 2009 | Hotpoint Dryers
Empty water light stays on and doesnt get hot
allways with this type of unit it is best to always empty the container after every dry,this is because when the water rises in the pump chamber it operates a switch which shuts of the heater and puts on the light. and they stick quite a lot,disconnect from power and rock the appliance from front to back quite hard and this should rectify the problem
Jun 27, 2009 | Dryers
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer not heating/drying
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD640 Front Load...
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Dryer cutting main power off after acouple of seconds
your heating element is the most likely cause of this. will need replacing
Nov 18, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
2,076 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
