1999 Pontiac Sunfire Logo
Posted on Dec 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you take off the window crank handle to get the inside door panel off.
Jeffrey Turcotte
Level 3:
  • Pontiac Master 8,991 Answers
  • Posted on Dec 07, 2010
Jeffrey Turcotte
Pontiac Master
Level 3:
Answers
8991
Questions
7
Helped
4372925
Points
33683
Please see my tip at http://www.fixya.com/cars/r6065762-removing_door_panels . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Use a paper clip to form a small hook--see picture at above post.
How do i take off the inside drivers door panel on a 2005 dodge caravan
Hi Roberta, here's the instructions on how to remove your door panel. I have to wonder though on why you are removing it, my guess is you window doesn't roll up or down and your replacing the regulator. Any way here goes.
REMOVAL
  1. Remove the plug and remove screw attaching door pull cup to inner door panel.
  2. Remove switch bezel and disconnect power window/memory switch.
  3. Remove screws attaching trim panel to door from below map pocket.
  4. If equipped, remove window crank. (Refer to 23 - BODY/DOOR - FRONT/WINDOW CRANK - REMOVAL)
  5. Remove screw holding door trim to door panel from behind inside latch release handle .
  6. Disengage clips attaching door trim to door frame around perimeter of panel.
  7. Lift trim panel upward to disengage flange from inner belt molding at top of door.
  8. Tilt top of trim panel away from door to gain access to latch linkage.
  9. Disengage clip attaching linkage rod to inside latch release handle (INSIDE DOOR HANDLE LINKAGE).
  10. Separate linkage rod from latch handle.
  11. Disconnect the power door switch, courtesy lamp electrical connectors.
  12. Remove front door trim panel from vehicle.
Hope this helps and have an awesome day Roberta!
The exterior door handle on my 1993 Nissan pickup broke. I have a new handle but can't figure out how to remove the inside door panel to get to the area where I can remove the old handle and replace with...
Inside door handle should have some screws that need to be removed and the window crank will have a c-clip behind it . or some you have to pop the cover off the window crank
2helpful
2answers
How do I remove the handle in door panel? I'm trying to remove the door because my window fell off the track, it doesn't have power windows so I have to manually roll them up and down.
1- remove the window crank
2- remove any screws from the door panel; sometimes they are hidden by a plastic cap. look inside the elbow rest cavity; remove any screws you see.
3- insert a flat plastic or wooden tool in the shape of (roughly) a scraper, between the door panel and door and start prying the clips which hold the panel to the sheet metal. get as close to the clips as possible with the tool, as that will be the easiest way. there are about 8 of these clips on an average door. when all the clips have come loose of the sheet metal, lift the panel straight up to remove it. you will find a metal rod attached to the inside of your handle; unfasten it and remove the panel completely. that handle looks like it is part of the panel and cannot be removed separately.
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
How too remove door panel and window crank handle on driver side on 2001 chevy van
On that model of van, you will have to remove the screws on the lower side of the panel, and in the door handle. The window crank handle has a spring clip in it that takes a special tool that is available at any parts store, but very easy to use (you just slide it up and down inside of the handle a few times, and it should pop off). After you have the screws, and handle off, you will need to "pop" the panel loose from the door. whille pulling on the sides of the panel, look inside of the panel to see if you can locate the pop in fasteners. When located, you'll have to have a screw driver, or similar object to pry the panel off of the door. (some of the fasteners might break, but are available at the part store) After the panel is loose, be careful of the door release handle, and with the window in the down position, take all of the switches loose from the panel and carefully raise the panel up and out.I hope that this is helpfull.
Need help removing a window crank handle on 2006 Kia Rio
between the plastik ring and the handle is a clamp wich has to be removed. it looks like an U and can be pushed out with a screwdriver wich is slightly bended
5helpful
How to remove the inside door panel from a dodge 2005 2500 pick up
FRONT DOOR TRIM PANEL - REMOVAL
Release door latch and open door.
Roll window down.
Remove window crank Window Crank - Typical , if equipped.
Remove screws attaching trim panel to door Door Trim Panel and Trim Panel Screw
CAUTION: Do not forcibly pull trim panel from door, damage to trim panel may occur.
Simultaneously lift upward and outward to release retainer steps from inner door panel Trim Panel Retainer
Disengage inside handle linkage rod from inside handle.
Disconnect speaker harness wire connector Speaker And Power Mirror Connector
Disengage power mirror wire connector, if equipped (driver's side only) Speaker And Power Mirror Connector
Disengage clips attaching power window/lock switch panel to door trim panel. Disengage wire connector from switch panel, if equipped Power Door Lock/Window Connector
Separate door trim panel from vehicle.
INSTALLATION
Position trim panel at door.
Engage wire connector for window/lock switch panel, if equipped. Engage clips attaching power window/lock switch panel to door trim panel.
Engage power mirror wire connector, if equipped.
Connect speaker harness wire connector.
Engage inside handle linkage rod to inside handle.
Align trim panel retainer steps with inner door panel and slide trim panel into place.
Install screws attaching trim panel to door.
Install window crank, if equipped.
Hope helped with this; remember rated this help. Good luck.
Avalon door panel
Below are the removal procedures for your vehicle's front inner door panel.
On models without power windows, remove the snap ring retaining window crank handle. Remove crank handle and cover plate.
Remove lower door frame bracket garnish. Using a screwdriver, remove inside door handle bezel. Remove power mirror control switch and disconnect harness connector.
Remove armrest panel. Remove 6 screws. Pry interior door panel loose from door.
1helpful
How do I remove the door panels to change the speakers in the front doors of a 1999 Ford Escort?
remove the front door pull cup screw
remove the screw cap and screw from inside handle and slide the handle rearward to disengage the hook from the inner sheet metal. disconnect inside handle from latch remote link if manual windows- remove crank with store bought remover tool. Remove the 2 pushpins from the door trim panel using trim tool pry away door panel [7] fasteners holding panel and push panel in and up . if elect windows disconnect switches
3helpful
1994 vw jetta drivers door window crank inside handle removal(man
You'll see a small ring on the inside of the crank where it meets the panel. That ring holds the crank in place. To remove the handle simple push the ring up and the handle will slide right off. Depending on the position of the crank the ring might have to be pushed up down or sideways. Hope that helps.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
