Question about Apple iBook Mac Notebook
My laptop won't charge
First my charger piece got stuck in the laptop then it came out and i got a new charger but now it won't charge
    Problem Solver:
  • 14 Answers
The the power adapter is faulty luckily its seperate from the main board and is pretty cheap look on ebay or go to http://www.ifixit.com for parts and guides on how to repair it
Posted on Aug 10, 2008
    Novelist:
  • 137 Answers
If you think you might have damaged the socket (the place you plug it into the computer) when you removed the piece stuck in i, the the first solution might be true. I'd try something easier first though.
1) make sure the adapter is good by testing it on another laptop.
2) check the end of the charger. If the circular piece surrounding the "prong" in the middle is bent so it doesn't make a complete circle, it might not be getting good contact. Press or pry this back into a circle.
3) make sure your battery can take a charge by either testing it in a friend's iBook. If you plug the charger in and it doesn't turn orange, check the battery indicator in the upper right to make sure it doesn't say something like "unable to charge".
Posted on Oct 03, 2008
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
Asus charger won't charge
Stop using that charger. I sounds like you have a break in the wire and when you hold it in the right position, the two pieces touch and current flows. Unfortunately the heat is probably being caused by arcing and is a potential fire hazard.
Apr 06, 2017 | ASUS Original 19v 3.42a Ac Adapter Charger...
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
WORX 24V charger won't charge
I'm having the same problem. Worked great then didn't last as long. Now I'm stuck with this piece of crap useless piece of equipment. I'm back to spending too much time trimming with scissors since I can't afford a new battery non the less a new trimmer. Thanks a lot WORX! It doesn't Work! I'll never buy another of their product!
Aug 26, 2012 | Worx 24-volt Cordless Electric Lithium-ion...
My N5010 dell laptop battery won't charge anymore. Could I just need a new battery, or charger, or could there be something else going on internally that I need to know about? For the most part, I
If your laptop is still under warranty, contact dell and they should be able to fix it free of charge, The same thing happened to my laptop a few years ago and fortunately, it is still under warranty, The fault is the charger itself which dell replaced free of charge.
Jun 26, 2012 | Dell Inspiron N5010 Laptop Core I5...
My dsi xl won't charge. I've bought a new charger yet it still won't charge
I have many times repaired small electronics with this problem by checking the solder connections from the power jack to the circuit board.(I am self taught,not an expert)Anything that plugs in to the device can easily break the connections to the board.Electronic manufacturers do this construction technique to save space,but I would rather have the jacks connected to the board with short pieces of wire.(I recently scored a Magellan GPS in the dumpster at work-someone pitched it WITH THE CAR CHARGER because of the same problem)It took me longer to figure out how to get the case open than it did to fix it!
Dec 31, 2011 | Nintendo Video Game Consoles & Games
Ok i have a Ibm thinkpad and my charger is stuck on green battery but it wont charge at all. It was working earlier but i turned of the computer the wrong way by holding the power button since i was in a...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 18, 2011 | IBM ThinkPad T30 2366 Notebook
Piece of charger stuck in I-pod
Just take it to a consumer elctronics or electronics repair shop
Nov 09, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Apple iBook Mac Notebook Logo
134 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
