Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Drum out of balance
When looked at from the top the drum sits to one side by 2-3inches. It can be moved back into a cental position but as it rotates with the motor it moves back a bit each revolution to the out of centre position.
When spinning there is a lot of vibration and it is easy to see that the drum is spinning off axis.
  • 3 more comments
  • brroklyn Jun 29, 2008
    The drum sits out of line when empty. I can realign the drum when empty, but during the spin cycle it gets off balance and out of align with the fill nozzle and I end up with water all over the floor! Any ideas on how to fix this???
  • 2weelsbetter Jul 02, 2008
    The details were very useful to help me get the casing off. I checked as you suggested, everything seems to be in order.
    I have found out the machine is only 18 months old, I bought it second hand. It is possible that the springs have become weak because the machine has been moved witout using the restraining bolts.
    Thanks for your prompt reply....John
  • Anonymous Jan 30, 2009
    does the balancing ring need to be full
  • clm2321 Feb 19, 2009
    I have a whirlpool LSQ854JQO that just started to shake during spin cycle. Counter balance spring is intact.
  • Anonymous Apr 15, 2009
    drum out of balance always have to try to center drum before wash or sometimes it will leak water. Also spin clycle out of balance.whirpool washer lxr9245eq1
  • 261 Answers
Hi Gerald, directly below the spring where it attaches to the basket suspension is a small hole, use a flash light to locate. If you get a chance, have you seen any dark metal shaving in the machine?
Posted on Sep 28, 2008
  • John Robbins
    John Robbins Oct 27, 2008
    Hi Gerald
    It is located on the back left side
Where exactly does this counterbalance spring connects. i pulled up the springs but after assembly it vibrates badly in high spin. But I am not sure if I connected the counterbalance spring correctly. Thanks
  • 413 Answers
There are a few things that can cause this issue.
1. The counter balance spring broke or the mounting hole for the spring rusted through.
2. One or more snubber pads may have come off.
3. The suspension springs may have stretched or broke.
Start by removing the shell as follows:
A.) Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
B.) With console lifted you will find a lid switch connector (white in color). Unplug the switch from the connector.
C.) There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
D.) Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
1.) The counter balance spring is located in the bottom rear. It should be attached between the cabinet and a bracket on the tub.
2.) Inspect snubber and corner pads. May be brown or white in color.
3.) Inspect suspension springs.
If you need further assistance, let me know
Posted on Jun 29, 2008
I replaced all balance springs. Still don't balance?
The washer is dancing across the room? Are the transit brackets removed? One on the motor, one across the top. Never known springs that needed replacing. With the top of the drum should move left and right a lot and backwards and forwards a little.
The washer must be level left to right and back to front. All four feet must be adjusted to sit evenly under the same pressure.
Bulky items or single large items will cause uneven balance. A normal load of socks, underwear, shirts, and a coupe of dish towels should keep balance as a test.
Oct 24, 2015 | Washing Machines
Out of balance washing machine
Hi, your question does not give me any hints so I will try to give you some general tips. If you wash things that can not spread out evenly inside the drum, like mats pillows etc. Disable the high spin and drip dry you items or squeeze out the water by hand.
If the drum swings from side to side when rotating, one of the shock-absorbers inside the machine may be worn out, broke or loose.
If you open the lid, grab the drum and move it a bit back and forth and side to side (not rotating) it should not swing easily but with a damped resistance when the absorbers are ok.
An other experience I have made is the balancing of the feet. I had a new machine that alway moved around during the high spin, even thou I have made an extra flat surface for it to stand on. I could recognize a bumping noise from the feet.
When I pressed down the left or the right front corner with my hand a little, the bumping stopped. Then I adjusted the corresponding foot down and fine tuned it until the bumping disappeared while spinning.
Since then my machine has not moved an other mm (= 1/25").
So equal down force from the feet and no play under any of them is essential to deep it from moving around.
Hope this can help you too.
Jan 24, 2015 | Washing Machines
How to balance a frigidaire washer?
Hello - Are you speaking about being balance without the leveling legs? Is the unit located on complete level ground? Or is the washer tub loose and unable to move? If you are referring to the drum, try rotating it manually when it is turned. If you notice that the drum is not balanced and cannot rotate freely, I would suggest contacting a professional so they can move forward accurately. Washer may possibly have a faulty bearing, unbalance drum or pulley issue.
Dec 06, 2012 | Frigidaire Washing Machines
It doesn't heat up and it's not the breaker.
may be heater coil, located inside machine on back right side. unplug dryer, open dryer door and remove screws, with a flat tip screw drive gently pry on each top corner till it pops off, gently move panel forward and disconnect door switch. sit panel aside, lift top all the way up it is clipped on the back so it will not fall off. look to the back and right and the coil looks like a spring, it is easy to change, all you need to do is will the make and model call a appliance store and they can tell the price for a new one. good luck tim
Sep 18, 2010 | GE DBXR463EBWW Electric Dryer
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
When turned on, the drum makes a grinding noise as
The main bearing may be worn out at the back of the drum allowing the drum to wobble.Reach inside the drum and lift upward. If you can move it up and down this is probably the problem.
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Jul 05, 2009 | Maytag Performa PAV2200
Hear a periodic banging during rotation of the drume
usually you can check it at the back cover, check if the dryer tub is directly mounted or connected to the motor, then check the rubber stabilizer or spring stabilizer of the motor which is connected to the base. This stabilizers are responsible of the balance of the dryer tub during high speed operation or rotation of the motor. check this stabilizers and replace it if it is defective or weak.
and one thing more, just make sure that when load your wet clothes see to it that you load it at the center of the dryer tub, so that when the motor starts to spin at speed it is in a balance position.
Jan 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Jul 15, 2008 | Whirlpool LTE5243D Top Load Stacked...
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,251 people viewed this question
Dan Webster
Dan Webster
Sal De
