STOVES 720ef Oven Programme won't go off automatic
This is a solution - of sorts - but probably not the one that you were hoping for.
My Stoves 720EF oven developed the same fault.
I tried pressing the buttons in various combinations and I tried switching the power off and on, restting the timer and the clock, no joy.
I then tried getting hold of a copy of the manual and trying to fix it, no joy. Called up Stoves and booked a visit from a specialist service engineer, costing £75 +VAT for the call out, and was advised that the engineer would attempt to repair it but it might need a replacement circuit board, costing a further £110 plus VAT.
engineer arrived on the appointed day and was straight onto swapping out the circuit board - not much scope for "attempt to repair" - so that was about £190 plus VAT to fix it. job took about 25 mins and didnt seem to need anything beyond what any electrician (or electrically-expert DIYer) could do.
comes with a 12 month warranty - hopefully it will work without any issues !
If you have a regular electrician you might prefer to buy the board and get your electrician to do the job - or do it yourself, assuming that you are suitably skilled and qualified.
hope this helps
cheers
David
I fixed mine, like this. Take out the four screws that hold the galvanised sheet metal panel which houses the clock and oven controls. Then, pull off the two brown and black spade terminals from the back of the clock display module. The oven will now work, but you will, thankfully, have no clock or timer.
Great fix saved me buying a new oven thanks Ciaran Trainor
Great fix - saved a worrying Christmas/New Year period. Many thanks
