I have an rca tv and it will not power up (after a thunder storm and breaker trip). Is there a rest button on the TV
  • 8,617 Answers
Try holding in the power button then unplug the set for a minute then plug back in. Also whats the model number of the set? and does the power led light up or blink when you press power> If it blinks how many blinks?
Posted on Jun 28, 2008
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
HELP! I think my TV got zapped and is ruined from storm!
Check whether the power outlet has power. If it has, I suggest please do not attempt to switch on the TV, unless checked by a qualified service technician.
Aug 16, 2012 | Toshib 46L5200U 46" 1080p LED-LCD TV -...
Kdl40ex401
Hi there!
One of reasons your tv not working, the thunder storm /lighting possibility has burnt your Tv micro processor. get a technician to check the power supply section too because during the thunder storm your TV circuitry received excessive voltage .
If is the main processor is burnt you have to change it for the TV to work .
Jan 10, 2018 | Sony KDL-40EX401 42" HDTV-Ready LCD TV
Just had a power outage from a thunder storm all lights came back except for tv and cable. how to fix?
Please check the power to the TV outlet. If there was a surge it could have tripped off. So confirm this before we go further to check.
If the power is present then there is failure within the TV , it can be the fuse but if the fuse blows off then the SMPS unit can be faulty.
So please check on the link below for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Sep 15, 2011 | Televison & Video
Toshiba Model 51H84. Power breaker tripped during a storm. Breaker reset, and TV will not power on. Is there a fuse? Is there a reset button of some sort? How should I proceed? Thanks.
Your TV has a fuse on power circuit board ( that is a standard part).You need to resemble your tv to get the fuse ( make sure to disconnect all power and antenna before doing this service). Usually any tvs use a clear glass cover on fuse ( you can see a small conductor inside the glass). Replace the fuse if the small conductor gets broken. If after the fuse replacement, you got no joy on tv, the receiver part could be get problem also ( due to storm attack) and need to repair / replacement.
I hope the storm only attack your TV fuse.
Good luck
Aug 02, 2011 | Televison & Video
Not getting power to tv.Socket and plugs are getting power ,there was a thunder storm,but every thing else fine.
The problem of your tv is the power supply the thunder storm cause that. You should unplug your tv when not in use, try to check the fuse if busted, their are two classification of a busted fuse, if the fuse is only open try to replace it but if the fuse is all burned out dont just replace it, it has a shorted parts like the regulator and the bridge type rectifier
Jun 24, 2011 | Televison & Video
A voltage spike after a thunder storm may be responsible, no power to tv. what do I look for?
IT SOUNDS LIKE YOU NEED A NEW TV BECAUSE IT IS FRIED IM LOOKING FOR A SCREEN HOW MUCH WILL YOU SELL ME YOUR SCREEN FOR.
Sep 06, 2009 | RCA P60921 60" Rear Projection Television
Emerson tv lost the ability to power on after a storm
I would probably look at the internal fuse that protects the power supply inside the tv. The storm probably sent a power surge through your outlet, your breaker may not always work correctly, especially if the breaker is old. The fuse should be inline with the hot side of the AC power to the power supply circuit. You would have to open up the tv, but you would be able to spot the fuse very easily. Fuses are cheap, but getting to it may be a problem
Aug 20, 2009 | Emerson Televison & Video
JVC 48" HDTV Ready Widescreen Projection TV
Terrible thunder storm can create electrict shock to our appliances thats why we recomended that if you donot use your tv pls unplug it, and it mostly if you use outdoor antena when the thunder hit the tv will damage.
Jan 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
