Question about HP Officejet 4355 All-In-One InkJet Printer
Hp 4355 all in one
My HP 4355 shows that there is a paper jam. However, there is no paper at all. I have already checked carefully and followed every step provided at HP website but I still have the problem
  • 84 Answers
The paper movement mechanism may have some problem.
If not so the paper movement sensor in the inner part of left side is having the problem.
The timing wheel may be out of alignment or the sensors may have dust over them....
Posted on Feb 11, 2010
How do i fix a "fake" paper jam in my HP Officejet 6700 Premium
Try using compressed air to blow it out.. or use a compressor that can do 150 psi.. you might have dust in the sensor..
Aug 27, 2014 | Office Equipment & Supplies
My computer says there is a paper jam but there is none on the display screen. I tried opening it up but it doesn't work, my computer still says it has a paper jam. My printer is HP Officejet 4355. My...
Turn the printer off.
Disconnect the AC power.
Disconnect the "data" cable from the computer.
Reconnect the AC power.
Turn the printer on.
Press the "paper-feed" button, to try to feed a few sheets of paper through the paper.
Reconnect the "data" cable.
If this fails, take the printer to a qualified technician, for professional trouble-shooting.
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Paper is not jaam but printer showing paper jaam again & again.
Several things can cause a jam. I can suggest checking the paper path very well, especially if you have had a jam in the past, a little piece of paper there could be triggering a sensor and causing the message. Another thing might be rollers worn out or dirty. If the rollers rotate 3 times and no pick up happen it will show paper jam, try a humid tissue to clean it.
Sep 07, 2010 | HP Officejet 4355 All-In-One InkJet...
How can i clear carriage jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Jun 08, 2010 | HP Officejet 4355 All-In-One InkJet...
4355 papar jam error solution
THE PRINTERS MANUFACTURED BY HP ARE HAVING THIS PROBLEM IN COMMON ALL THE WAY. WE SHOULD TAKE FOLLOWING PRISCPRIPTIONS WHILE RUNNING THESE PRINTERS
1. LOAD PAPERS AT SOME DISTANCE FROM THE PAPER LIFTER THAT MEANS KEEP THE PAPERS SOMEWHAT BEHING YOU KEEP THEM
2. WHEN THE PRINTERS ARE OLD THEM GET THEIR PAPER LIFTER CHECKED AND TRY TO PRINT ONE PAPER AT A TIME.
THANKS
PROUD TO BE AN INDIAN
KAMAL DEV JHALLI
HAVE A GOOD DAY
Nov 25, 2009 | HP Officejet 4355 All-In-One InkJet...
We are having problem with our HP Officejet 4355 All -in-one Inkjet Printer. When we are scanning the paper is not moving inside. I Think a piece is troubling inside. How to remove paper. How to open...
the scanner feeder mechanism may have some problem.
Get it serviced from nearest service centre or your vendor...
There is a door back of the printer to clear paper particles and jams. carefully open, clean and re fix it on its place.
Nov 05, 2009 | HP Officejet 4355 All-In-One InkJet...
Paper jam but no paper at all
all sencer of printer clean care fully.
May 18, 2008 | HP Officejet 4355 All-In-One InkJet...
HP Officejet 4355 All-In-One InkJet Printer Logo
200 people viewed this question
Seeker5211
Seeker5211
