Question about Sylvania 6427TE 27" TV
Colors are messed up
One day I turned the tv on and the colors all seem very purple...we tried adjusting color brightness...and all that and nothing once in a while the screen goes green with lines across but if i turn it off for a while that will go away but not the purple hue everything has...please help!
    Problem Solver:
  • 25 Answers
The deguasser in your tv may not be working right..or the magnets in the corner of your tv has moved....it can be manually deguassed but a tv shop would have to do it..
Posted on Aug 28, 2008
SAMSUNG LCD 550 SERIES TV COLOR GREEN AND PURPLE
Sounds like t'Con board fault. Contact any service technician to make it confirm.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, screen faults & possible causes to LCD screen are given with illustrations.
Jul 29, 2014 | Samsung Televison & Video
Picture has red tint
I would unplug it from the wall for a while and see if that will help reset it. Also make sure there are no magnetic devices near the screen because this will change the screen color as well. Mine will mess up every once in a while so I just unplug it while I am off running errands, plug it back up when I come home and it seems to reset itself. Good luck
Jun 15, 2014 | Emerson EWF2004 20" TV
TV picture just turned orange suddenly, what do i do to have a perfect picture resolution again?
Well the color has nothing to do with "perfect picture RESOLUTION". Go into setup and try to adjust the colors...or amount of color...same with brightness. Also check any automatic setting for the screen or picture.
Oct 30, 2013 | Hisense Televison & Video
The image on the screen looks like everything is in slow motion, the the color is messed up. I have already tried adjusting contrast, brightness, etc. Is this a fixable problem, or should I just buy a...
I know the colors are all messed up.But the tv LCD screen panel light it is bright enough to see the screen picture,and the tv LCD screen panel are clear,no purples,reds marks or bruses to the tv LCD screen panel itself?Yes,to all of these.The tv can be fixed.The tv Tuner signal board,that the board where the incomming broadcasting signal wire plug into it.The tv Tuner signal board it is dying and the problems to causes this.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.Will fixed this tv and get tv this to be working normal again.
Aug 20, 2011 | Samsung LN-T3253H 32 in. LCD Television
My hp monitor's colors are messed up.
Did you already try it on another PC?
Try new VGA cable?
Otherwise you may have to open it up and look inside for failed components.
http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Color wash at upper right corner of screen and lower left corner, color bleed. Resembles the colors of a florescent yellow or purple highlighter.
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
  • Halos around objects
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 27, 2009 | Panasonic PT-61HX40 61" Rear Projection...
Cant figure out color issue with computer.
Well...it's a Dell and even when it's well...it's still a Dell.
Have you tried the monitor on different system to eliminate the tower being the problem? Some have updated and/or rolled back drivers to help cure this problem, which seems to be a common issue with this LCD. Personally i think the contrast ratio is inadequate.
Good luck with your Delllll...
May 14, 2009 | Dell E176FP 17" LCD Monitor
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
PROJECTION TV Phillips 9P6031c103
this is what convergance looks like;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
if pix is dark their is 6 adjustments knobs in the front of the tv under the screen and behind the plastic cover. the top three are the brightness bottom three is focus.
Nov 24, 2007 | Toshiba 53H71 53 in. Rear Projection...
Sylvania 6427TE 27" TV Logo
301 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
