Question about JVC Everio GZ-MG30 Camcorder
My camera will not turn on. It doesn't matter if the battery is attached or not or if the camera is plugged in. when switch on my camera the red lights on top comes on. but the screen is dead and it will switch off. again some times if i change the screen in up or down direction it will work. why
I am having a problem with a borrowed everio (gulp) -
it will only power on if attached to the wall charger - otherwise, it wont recognize the battery - although the battery is full and works fine with other everios. an expert said they were made poorly and i just have to take it in to service
Posted on Jul 21, 2008
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
Battery level
As Suzaku explained:
A battery icon will show up on the LCD screen of your camera when it is already low and needs recharging. It can be found at the lower right side of your LCD screen. The ready light of your camera will also blink red and your camera will turn off if the battery is exhausted.
NOTE:
The icon will not appear if the batery is sufficient and there is no TECH way of making the icon show until the batt needs charging.
Jan 04, 2009 | Kodak EASYSHARE M763 Digital Camera
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
Mar 27, 2017 | Kenko MC-4 DG for Nikon AF 2x (MC4AFNDG)...
There is two circuite proctectors near by the power connector on the main board.try to check or replace the same.
Feb 18, 2008 | JVC Cybercam GR-DVL920 Mini DV Digital...
Camera "dead"
Did you try taking the batteries out? If not, try that and then put them back in again. This might reset the camera back to normal. Also, try turning the dial. Make sure it is at the camera setting, then try shutting it off. Further, move the dial to Set-up, and scroll down to the Reset all setting, press the right arrow and answer "Reset".
Sep 18, 2006 | Nikon Coolpix 5600 Digital Camera
JVC Everio GZ-MG30 Camcorder Logo
292 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
