Question about Hotpoint Aquarius WF000 Front Load Washer
Excess noise excessive noise on spin cycle and when i checked the drum there is excessive freeplay in that aswell sounds like bearings to me but i am only a vehicle mechanic and would like some expert confermation thanks in advance keith !!
I'm no expert either, but you're probably right. if you don't change worn bearings the shaft will get scored eventually and it's a much more expensive job.
Slip the drive belt off and turn the drum by hand. If it's quieter now, then the motor bearings are probably wearing out too.
Juxon
Posted on Jun 28, 2008
Auto washing machine drum vibrates makes loud noise
When machine is empty use fingers to try and move drum side to side. Is there excessive movement? 2 to 3 mm is ok. If drum moves to much it will be the drum bearings. Easy fix for an engineer or competent diyer. Millions of how to videos on utube.
Oct 04, 2015 | Whirlpool Washing Machines
Spin Cycle is very loud on front load washing machine
See here
How to fit a Bearing in a Washing Machine | Appliance Repair Help
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
From
DIY washing machine repairs (2)
for repairs check
Sep 04, 2008 | Washing Machines
Excessive noise while spinning
Hi.
Have a look at the drum bearing, that is the most common cause for noise on the spin part of the cycle.
Regards.
Ginko.
Jan 06, 2011 | Tricity Bendix AW1000W Front Load Washer
Drive belt snapped what is the cause
There are a couple of reasons for belt snapping.
1-Main drum bearings siezed, thereby caosing excessive friction, and belt to snap.
2-Motor siezed up, again causing excessive frictional wear on belt.
Try spinning drum by hand, it should be free, with no noise from it, if it runbles or feels rough, then drum bearings have failed.
3- Drum pulley loose or cracked, check the pulley for cracks or fractures.
Dec 23, 2010 | Hotpoint First Edition WMA22 Front Load...
Machine making a loud noise in spin cycle. We
Inspect the outer drum to see if one of your springs has popped off. You can also inspect the lower drum area to see if your vibration dampener has worn out or broken free. Also you may need to check your rear bearing just between the large pulley and the drom to make sure is hasn't separated from it's mount.
Mar 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Getting a real loud noise when spinning - sound like the bearings may have aproblem. How do I check
with the unit empty spin the drum by hand, you should feel the resistance of the drive belt and motor and hear the whine from the motor but nothing else, no grinding or lumpiness.
You can usually tell by excessive dirt at the back of the drum aswell right in the centre where the bearings are. If they are breaking up they tend to make a mess and break up the housing or shaft too
Jan 30, 2010 | Indesit WA 125 Front Load Washer
Drumming n/s font wheel
sounds like wheel bearing but first check that brake is ok and not binding check pads for excessive wear spin the wheel listen for any noise from bearing if bearing worn see my solutions for 850 volvo bearing replacement same as S70
Jan 12, 2010 | 1998 Volvo S70
Clothes washer vibration during spin cycles
the vibration and noise is most likely from the drum bearings wearing out to test the bearings try this out,,,
open the door, hold the top of the drum and lift it up, if it has any free lift in it the bearings are going, now spin the drum by hand and you should here the rumble off the bearings
Dec 29, 2009 | GE WPXH214A Front Load Washer
Zanussi Nexus has started making excessive noise on spin cycle drive side bearing is OK but the drum seems loose at the door end and there is a strong smell of burning rubber. How can I fix this ? Help....
loose drum sounds like drum bearing Faulty ..Most models sold as spider kit in cludes bearings and spider assembly, if its more than 5 yrs old then perhaps not worhtwhile due to cost of parts here in u/k parts approx £80 =+ Labour..hope this helps you
Nov 11, 2009 | Washing Machines
Noise when on spin cycle
Check inner drum for excessive play, if so Bearing fault. Could also be loose motor mount or Counterweights.. Good luck
Sep 29, 2009 | Frigidaire FTF530FS Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
65 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
