Question about Admiral AW22 Top Load Washer
Admiral Top load washer won't agitate and squeals
My top load Admiral washer will fill fine, then squeals a bit and then stops when it gets to the agitation part. We have replaced the belt and taken it mostly apart. Please help.
  • toby bennett Sep 20, 2008
    my washer worked fine until it went to spin the water out the agitator would not spin all it is doing is making a binding and clicking sound cant turn drum by hand
    Scholar:
  • 116 Answers
Sounds like the gearbox, unfortunatly this is sealed and is cheaper to replace the machine, presume the machine is quite old.
Posted on Sep 11, 2008
Hav3460aww
It sounds like the motor is heating up and tripping the overload. The squealing is probably coming from you pump. Tilt the washer back and turn the pulley for the pump by hand and if it make the squeal, replace. If it does not you may have a bad transmission.
Apr 28, 2014 | Maytag HAV3460AWW Top Load Washer
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Washer Doesnt Agitate or Spin
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
My Maytag Top Load Washer was in the beginning of the wash cycle with a large comforter when it began squealing, sounded like from a belt within the machine. I smelled a burning smell and stopped the...
The belt has been ruined. Basically there was to much load on the belt. You will need to replace the belt, maybe a 20 dollar fix and should take no longer then 15 minutes. Just make sure that before you go to the parts house, your remove the old belt and take it with you along with the model and serial number of the machine.
Please rate.
May 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Admiral lg capicity washer won't agitate or spin
Sounds like the belt is broken. Yes you can fix yourself. Lift top, remove front cover, belt is at bottom, not to hard to replace. If belt is not broke let me know, I will go further.
Jul 17, 2009 | Admiral AW22 Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Admiral Washer not spinning
broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
Jul 07, 2008 | Admiral AW22 Top Load Washer
Squeal that sounds like belt spippage
The motor slides back and forth so there is know way to tighten the belt.The new  belt is needed if your old one shows any ware or if has shiny look to it which would mean its been getting hot and slipping.
May 16, 2008 | Maytag Legacy Series Top Load Washer
Admiral Washer model #LNC6757 will not agitate
Possibly a loose agitator, try lifting the agitator, if it lifts then it is un secure, remove the softener cap and down inside the agitator you will see the fixing bolt,
You will need to lift out the agitator to retrieve the bolt if it has come fully un done, refit the agitator and secure using a socket and long extension bar.
Apr 15, 2008 | Admiral AW22 Top Load Washer
Admiral top load Admiral washer
Could be the motor or belt, tilt the machine backwards and look underneath to inspect the belt, try turning by hand see if everything is free (will only freely turn in one direction only as brake acts in one direction). Check motor for rotation, remove the front panel for a look, to remove the front panel, at the seam between the front panel and lid push in a flat knife or screwdriver approx 4" in at each side to release the clips (one at each side). this will allow you to lift the top and then remove the two front panel fixing bolts 7-8mm to remove the front panel.
Mar 24, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
408 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
