Connect two computers together
I want to know if possible can u hook two computers together with an ethernet cable and if one has a wireless internet connection can they both use it
  • 2 more comments
  • setharoni Jun 28, 2008
    how much would the crossover cable cost
    and how exactly do i set it up
    thanks alot man
    ill go get a crossover cable tomorrow and hook it up
    if i can get it to work right ill post again
    thanks bud
  • setharoni Jul 03, 2008
    can you give me some step by step plz
  • setharoni Jul 19, 2008
    sorry i havent posted results for u but i was on youtube tryin to find out how to use xbox live through my laptop
    it worked great then i tried it the same way onmy desktop and it worked great too
    alls i had to do is enable internet sharin from my laptop and i used a regular Ethernet cable
    Brigadier General:
  • 6,966 Answers
Technically, yes. Both computers should have an Ethernet port (LAN), a crossover networking cable, peer to peer networking using static IP add, and Internet Connection Sharing on the PC with the Wireless Internet Connection. If by chance the PC with the Internet access is already using its Ethernet port, a second NIC could be installed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 28, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Jun 28, 2008
    Hi again,
    If you would have clicked on the link (crossover) provided, then that would have started you off. In any case, a Google search disclosed tutorial on how to go about this here, here, here or here.
    As to the cost, perhaps if you could have posted your general location, then possible sources and most likely cost could be forwarded. Again, in any case, the ball park cost for a crossover cable would be in th neighborhood of 5USD.
  • Louie  Role
    Glad to be of assistance.
  • Louie  Role
    Louie Role Jul 20, 2008
    Appreciate the update andcongratulations on the success of your project.
I just bought a laptop computer and I already had a desktop. My internet provider is Hugesnet Satelite. I bought a Netgear N600 wireless dual band router thinking I could just hook it up to my desktop...
The HN9000 should have an ethernet port. You will require two ethernet cables to connect the desktop to the router.
1. Connect the ethernet cable from the Modem to the Ethernet Input port on the Router (It is generally placed away from the other ports on the back of the router.) 2. Connect another ethernet cord from one of the output ports on the router to the desktop computer. 3. On the laptop, turn on your wireless card. The process for this differs from computer to computer. If you were to provide the model of laptop, I could provide you specific instructions. 4. The network setup should be complete.
If you need more help, let me know by replying to this solution. Thank you for using FixYa!
Apr 01, 2011 | NetGear Computers & Internet
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
I dont know how to set up my routers
Put the setup disk in your computer and it will step you through the process.
Typically, you will have to hook your computer directly to an internet connection (with ethernet cable), then unhook it and connect the internet cable to the router (usually in port 1), then connect an ethernet cable from the router to your computer and plug in the router.
The disk should download the appropriate software and walk you through setting up a password and stuff.
After all that, you can unhook your computer and use it wirelessly.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
Set up
No. You do not need to have a computer connected via a CAT5 (Ethernet) cable to the router for a laptop to access the wireless signal.
However, to set up the router to broadcast that wireless signal or to alter some of the wireless security settings you will have to connect directly to the router with a CAT5 (Ethernet) cable.
If you need assistance connecting to that wireless connection, let me know. I have some instructions which can help retrieve the security information from the router so you can connect to the Internet via the wireless signal.
Mar 20, 2009 | Belkin (F5D7230-4) Router (587009)
I can't hook my computer up to my phone line for internet. I have my router and another desktop hooked up to the phone line through the router.
That modem is in itself a router. However it only has one Ethernet port and no means of broadcasting a wireless Internet Signal which makes its function of a Router somewhat useless. What you need a(n) (wireless) access point. The Access Point will give you more Ethernet slots allowing more computers to be connected to the modem/router via CAT5 (Ethernet) cables. Depending on if you get a Wireless access point or not you might also be capable of using a wireless adapter to connect to the 2wire and get Internet access.
Let me know if I need to clarify any of the points above or if I can assist you further.
Mar 16, 2009 | 2wire 1800HG Router (RG1800HG00)
Hooking ethernet to broadband router and cable modem
Hi Sherry - The etherport port on your modem should be connected to the WAN port on your router. You then connect your pc to one of the 4 ethernet ports on the router. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Jul 10, 2008 | SMC Universal Wireless Broadband Router...
I dont know the correct way to hook up my cable modem, computer, and wireless router together
hello!
-- is this a brand new router?
-- who is your internet service provider?
-- what is the brand of your modem?
-- what is the operating system of your compter
you may try the basic connection:
-- while the router is powered on, reset the router for 10 secs
-- turn off your modem, router and computer
-- from the ethernet port of your modem, to the internet or wan port of your router
-- from one of the regular port of your router to the ethernet card of your computer
-- turn on the modem first, after 5 secs, turn on the router, another 5 sec turn on your pc and check if you can get online
May 01, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
