Question about Nu Mark Numark Cdn36 Dual CD Player CD Player
Cdn36 pbm the left deck is making screeching noise. cd cleaner did not help.
    President:
  • 624 Answers
Does it make this noise only while playing a disc? or is it when it opens and closes.
If it happens while playing a disc, it could be the spindle motor or something rubbing on the disc while it is spinning. Since nothing is supposed to be rubbing on the disc, it would need to be taken apart and looked at while it is spinning to see what that is.
Let me know if I can help you any more,
Good luck,
Dave
Posted on Jul 01, 2008
I have vms4 decks, when i play a tune on my right deck i get serious crackling noise out of my speakers and headphones...any advice please guys?
Have you tried isolating the problem, like switching cables from the left side that is not making noise? Also check connections,
I say this all the time and use all the time.... electronics spray contact cleaner, usually takes care of crackling noises
really hope this helps?
Mar 04, 2015 | American Audio VMS4
Engine screeches when running. revving the motor makes it stop momentarily
Could be a belt screeching. Fan belt, A/C belt, Serpentine Belt, alternator belt, etc. Easiest way to isolate which belt is to open the hood and use your ears to see where the screeching is coming from. Left, right, front, behind the engine? Spray some WD-40 on the belt you think is making noise and if it quiets right away, then that is the belt making the noise. Either the tensioner needs adjusting or the belt needs replacing. The WD-40 does not hurt the car, it'll start screeching again in a few days when it wears off.
Sep 30, 2013 | 2005 Chevrolet Express Cargo
Hi, my dc07 cleaner has developed a very high pitch screech its not a constant sound but intermittent and last for a second or two and is very unpleasent, its a loud cleaner anyway but this noise is so...
hi.
it sounds like the bearings in the motor are worn out. the only solution is to change the motor, or the entire hoover. motors are available from ebay for about £35 and it will then need to be fitted. unfortunately these bearings do wear out eventually. once they start to make screeching noises like this, there is not much life left in them, and they will get worse rapidly.
if you decide to change the motor yourself, please feel free to ask for more details on how to do it.
hope this helps
Aug 16, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Screech noise from ps2 slim
Sounds like the laser may have gone bad on your system, try this - use compressed air to clean out the system, where the laser is, and other openings on the device. Then clean your game disc with a CD/Game Disc cleaner (bought at any gaming stores), try this. If this doesnt fix the problems then i would contact SONY and have them replace your system or atleast maybe they could try to fix it. Good Luck!
Jul 13, 2010 | Sony PlayStation 2 Slimline Console
IT POWERS UP FINE BUT IT DOESNT SEEM TO BE READING THE CD'S I PUT IN EVEN ONES IT HAS READ IN THE PAST.
the lens cud be dirty or damaged or the cd spindle motor has gone bad. in case of dirty lens try using lens cleaner cd. that dont work means probably spindle motor is out.
Mar 12, 2010 | Nu Mark Numark Cdn36 Dual CD Player CD...
I have a numark dual cd player and one of them doesnt play the cd's
the laser may be dirty.
Use a can of compressed air if you have a can; otherwise, get a laser cleaner ($13 Radio Shack).
It is an "audio CD" with tiny brushes on it. Read the directions carefully, and have your speakers / headphones on.
No chemicals involved.
Sep 28, 2009 | Nu Mark Numark Cdn36 Dual CD Player CD...
Loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Apr 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cdn 36 pbm
unit needs internal cleaning. cleaning cd probably won't work.
Oct 27, 2008 | Nu Mark Numark Cdn36 Dual CD Player CD...
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
Cassette player works fine, then screeches after 20-30 minutes.
Yeppers very common problem .. If the noise dosent come from the speakers then the problem is in the motor in the cassette deck. if the problem comes from the speakers when the deck is playing a tape, then the problem is in the record/playback switch. you may beable to fix it by spraying just a lttle bit of tuner cleaner inside the switch. It shouldnt cost much to have a repair shop do this as if you spray too much your going to ruin the belts and the mechanism. Good Luck
Jul 31, 2006 | JVC UXN1 Shelf System
Nu Mark Numark Cdn36 Dual CD Player CD Player Logo
115 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
robert landry
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
