Question about Ovens
St george canopy rangehood Model HC90-2S
This rangehood is about 12 years old and the light has blown and we cannot remove it. Does anyone know how to do this? Do we twist it, or just pull it? Please help. Nobody in any of our appliance shops has even heard of the make. It is Australian made.
5 Suggested Answers
  • 93 Answers
SOURCE: I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Posted on Sep 12, 2009
  • 512 Answers
SOURCE: St George Oven Door - Glass Broken
http://www.sga.com.au/User-Manuals/default.aspx
Anyway that will get you to the right people.
Posted on Sep 20, 2009
iwillfixforu
  • 619 Answers
SOURCE: Readout on control panel has faded so that you can
It is less expensive than replacing the whole stove if you do your self. Should be able to find parts a repairclinic.com. Hope this helps.
Posted on Feb 02, 2010
bongkito
  • 344 Answers
SOURCE: I need a manual for
Good Day Natalie!
You can go to http://aussiewhitegoodsrescue.com.au/agents/Use_Care/RH/KM_RH/Artica.pdf
and view this online manual. You must have an acrobat reader installed in your system to view this file because its pdf format.
Good Luck Natalie!
Please accept.
Thank you for asking Fixya.
Posted on Jun 29, 2011
The lights on the under side of the rangehood do not work .i have replace the bulbs ,the exhaust fan works ,is their a re set switch
could be a blown transformer to supply the correct power to the lights or a loose connection on the light holders.
Aug 23, 2010 | Ovens
Hotplate won"t turn off st george cc-600 cooktop
I have a St George glass cooktop with temperature sensor light.It takes forever for the light to go out when I use the main element and that section often feels like it is still heatinglong after it has been turned off.Can there be power leakage through the switch for the main element
Aug 21, 2010 | Ovens
Hi the temp on our st george oven, model ueo-8 has become unreilable?
if digital the replace the oven control / if dial then the dial is at fault . mm
Jul 12, 2010 | Ovens
Readout on control panel has faded so that you can hardly see it. Sometimes does not turn off oven causing overheating alarm. Have to turn off at power box. Is it expensive to replace control panel? St...
Feb 02, 2010 | Ovens
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
Depending on model-
Sep 12, 2009 | Ovens
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 | Ovens
Ovens Logo
78 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
