Question about 2wire 1800HG Router (RG1800HG00)
I HAVE A 2WIRE 1800 ROUTER connected to talk talk. I ahve been advised to change the MTU to 1432 for secure websites to work. Is it possible to change it from the current default of 1500. I have connected a cheap router for the time being and this defaluts to 1492 mtu and it works fine. any help would be gratefully received
Type in 192.168.1.254/management in your browser's (ie) address bar, enter the syetem password and then go to "Configure Services" under the "Advanced" list. you can force the Upstream MTU there.
Posted on Jul 22, 2008
Download the driver
Posted on Jun 30, 2008
  • siow_cha_bo Jun 30, 2008
    i need to install the 2wire USB Remote NDIS Ethernet..cause i dun have the cd..so i need to download the software..pls help me
The dsl is red and when it turn green i still can connect to xbox live, but when i try to connect my xbox says i need a higher mtu is that possible to change from a laptop
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 21, 2011 | 2wire (1000-400108-001) Router
I have a 2Wire modem and i need to Change my Mtu settings how will i do this?
A computer's MTU or maximum transmission unit is a measure of the amount of data that can be sent over a specific network protocol at one time. Because the various network protocols on your computer all have to communicate with one another the MTU of your system can have detrimental effects if improperly set. The MTU most often referenced when talking about PCs is the TCPIP MTU. This is the MTU value used for all internet communication on your computer.
  1. tep 1 Launch DrTCP and select the proper network adapter from the "Adapter Settings" pull down list box at the bottom of the program. The adapter you choose should be the one physically connected to your modem or router for internet accessmag-glass_10x10.gif via an ethernet cable. You can find proper hardware name of the adaptor by going to the windows control panel and clicking on "Network Places" to see which adaptor handles your internet connection.
  2. Step 2 Enter a numerical value between 1400 and 1500 in the text box labeled "MTU". This numerical value is transmitted to every remote server you request data from to be used as a common size of data to be sent with every packet of data sent to your computer. It is advised you start at 1500 and move down in increments of 10 until a satisfactory result is found. Usually MTU problems are not a result of your hardware or the remote server. The problem almost always is ISP hardware not supporting frames as large as you and the remote server have agreed upon sending. Lowering your MTU value in increments allows you to find the largest size possible without having packets dropped due to being too large.
  3. Step 3 Click "Save" and exit the program by clicking "Exit" or clicking the "X" button in the upper right corner of the windowsmag-glass_10x10.gif form.
  4. Step 4 Restart your computer for the changes to take effect and check to see if the changed MTU has increased system network performance. This process of trial and error may require several attempts to find a setting that is optimal depending on your specific network configuration. If you are unable to find an MTU setting that works a quick call to your ISP to ask what their recommended MTU setting should resolve things.
Nov 15, 2009 | 2wire 2700HG-B Router (2700HGB)
I have a xbox 360 that fails the mtu portion of the network connection. i have at&t dsl that is run through the phone jack to the router ( 2wire 2701hg-b) and from the router to the xbox. what do you...
check on the MTU settings of ur 2wire.
This are the steps to see what ur MTU setting is:
>connect a computer to the 2wire
>open Internet Explorer, Safari or Firefox
>enter this on the address bar: gateway.2wire.net/management
>enter ur system password (in case u forget this, click on i forgot my password to get a hint)
>look for Advance in the column on the left
>click on configure services
>on the bottom, u shud see the MTU number
** i searched online and accdg to xbox tech support, ur MTU should be in the range of 1364 to 1500 **
>click on submit after u change the setting
just in case youve entered the correct MTU setting but it still does not work, u might need to contact either xbox or ur internet service provider.
Keep me posted on this one.
Dec 24, 2008 | 2wire 2700HG-B Router (2700HGB)
It is possible that my router is blocking some sites
It is quite possible. You may have to access the user interface of your 2wire 1800 gh and then enable secured site access. You may have to open port 443 or lower your MTU to about 1400 or 1300. Please PM if you need further information
Jul 26, 2008 | 2wire 1800HG Router (RG1800HG00)
2 wire 1800 router on talk talk
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
Apr 27, 2008 | 2wire 1800HG Router (RG1800HG00)
MTU problem
after some research!
you can change the upstream MTU
connect to your router with its ip address put /management after.
example 10.0.0.2/management. go to advance - configure services.
the last entry should relate to MTU. If it is not there then you ahve a custom Frimware loaded. Yhis is the case for me which is 3.5.5 I have contacted 2wire.net and requested a suitable firmware. If i ahve no response then a new router it is.....
Apr 17, 2008 | 2wire 1800HG Router (RG1800HG00)
Msn contact talk failure
Can you access other website? If you can the problem is not on the router but on MSN
Dec 30, 2007 | 2wire 1800HG Router (RG1800HG00)
Slo connection to some sites
Log into the router's management console page at page at http://192.168.1.254/mdc
On the left side under "Advanced", click on "Configure Services"
Set the "Force Upstream MTU" value to 1396 then hit Submit. Reboot the modem/router.
Nov 28, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG - B
Log on to the routers interface and look for MTU size. Once you get there, reduce it to 1492. This will help.
- Ranjit
ranjit@supportminds.com
Nov 02, 2007 | 2wire 2700HG-B Router (2700HGB)
Router blocks MSN and https: secure sites
I had exactly the same problem. Check your mtu settings on the 2wire. I think the modem is set at 1450 (or there abouts) An article (sorry can't find a link) suggested raising it to 1500 this didnt work for me so I started reducing it instead. Once i set it at 1400 mtu I was able to log on to secure sites again. Hope this helps.
Feb 06, 2007 | 2wire HomePortal 1800HG Router...
2wire 1800HG Router (RG1800HG00) Logo
151 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
