Question about Compaq Keyboard
Compaq laptop keyboard probs
Every few strokes the text is inserted elsewhere on the page--like the cursor jumps back to different box (fields) on page.
I´ve had a problem like this with just about every notebook I ever used. I assumed it was caused by some part of one of my hands touching (ever so lightly) the touch pad, and thus changing the cursor position.
The only solution I ever found was to use an external mouse and to disable the touch pad (via BIOS, I think).
Posted on Nov 06, 2008
  • 92 Answers
First make sure the tab key isn't jammed, if not then try updating the drivers for the keyboard. to do so go to start>control panel>system>hardware>device manager. Then expand the "keyboards..." category and double click on the appropriate one. then when the properties window pops up, click on the driver tab and click on update driver
Posted on Jun 28, 2008
  • 106 Answers
Just check if ur enter key is left pressed or its jammed,
Why is my spacebar scrolling at times?
Hi Norman,
The keyboard acts as a text tool when you've clicked in a text box and as a scroll button when you click outside a text box on a web page. Since you say you have a laptop, I'm guessing that you click the text box to type, start typing, and while you're typing, your palm touches the mouse track pad just enough to register as a click while the mouse cursor is elsewhere on the page. I'm not sure if there's a setting to make the space bar stop scrolling altogether but there are settings to make the track pad less sensitive if your track pad manufacturer supports it. For WIndows 7, go to Control Panel>Hardware and Sound and click Mouse under Devices and Printers. As mine is a Synaptics device, this window gives me an extra tab with extra settings. It may be worth checking out yours to see if you can turn down the sensitivity. Some laptops also have a handy key combination to turn the track pad on and off. Mines Function F7, but it's probably manufacturer specific. Check your laptop documentation to see if this might be an option.
May 08, 2014 | ASUS Computers & Internet
Keyboard jumps up to line just typed
Sounds like you have a sticky up arrow key,or you have a virus on your comp.Try booting in safemode by turning on your computer and tapping the F8 key while booting,then choose safemode.Once you are in Windows,open the program you are using and try your text document again.If it works correctly,you may have a virus.While you are in Safemode,run your virus scanner,then reboot your computer to see if the problem is solved.If it does not fix it,try running System Restore back to before the problem started.Good luck :)
Apr 22, 2013 | Everex StepNote VA4103M Notebook
Cursor and text jumps for dell inspiron 1150
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens. Type "Cursor blink" in the "Search programs and file" text box. A list opens. Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens. Click the "Speed" tab. A list of options appears. The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast." Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale. Click "Apply." Click "OK." The cursor stops flickering on the screen.
Feb 04, 2013 | Dell Inspiron Computers & Internet
I have a Compaq Presario CQ62. When typing anywhere, the cursor randomly jumps to another spot in the text and continue inserting text there. How do I correct this?
This typically happens when the typist's palms touch the touchpad, which the pad treats as a mouse click. See if the cursor is jumping to where the pointer is.
Most touchpads have a control panel (usually part of the MOUSE Control Panel) where you can reduce the sensitivity (or disable) the left click function from tapping the touchpad.
Apr 20, 2011 | HEWLETT-PACKARD Compaq Presario CQ62210US...
While typing a line of text , I will look at text only to discover that it has jumped back and start typing somewhere in the text. It happens so much that I have to type with only my fingers touching the...
I have had exactly the same problem with most laptops I have used in the last 5 years, Compaq, Dell and HP.
what is happening is simple. as you are typing you are inadvertantly skimming the touchpad or the cursor buttons with the base of your thumb - well thats what I was doing - and moving the cursor.
I got an external keyboard & mouse - worked for me!
if there is a setting in the BIOS that enables you to turn OFF the touchpad and / or keyboard cursor buttons when an external KB / MOUSE is connected then enable it otherwise your problem will still continue.
Unfortunately, if youre using the laptop away from base, or there isnt such an option in the bios you basically just have to be more careful!
Nov 28, 2010 | Acer Aspire 5315 Notebook
When I try to send eg. e-mail cursor jumps back
Two things come to mind.
1) bad mouse. Try a known good one.
2) touch pad has problem. Try turning that off in your mouse settings.
Jan 15, 2010 | HP Compaq Presario C700T
My Asus Eee netbook keyboard seems to "cut and insert" when I am writing sentences. I will start writing and all of a sudden I will notice that it will start typing from wherever the cursor was to begin...
My eee netbook will do that too. it seems that parts of my thumbs or palms tend to hit the touchpad at times clicking the cursor on different parts of the page? could this be happening to you? try disabling the touchpad with the little silver button on the left hand side of the keyboard at the top. If this does not help, you may need to replace the keyboard. It can be ordered from the asus online store.
Hope this helps you!
Sep 03, 2009 | ASUS Laptop Keyboard for Asus Eee PC
When I type my cursor continually jumps around to different lines
Well, you could try this...
Go to Start>Controlpanel>mouse>pointer options. At that page tick "Hide pointer whilw typing"
Hope it works for you:)
May 06, 2009 | Toshiba Computers & Internet
Cursor skipping and jumping back into previously typed text
Have a D600 myself and found anothe post that worked for me!
First, my problem was replying to emails the cursor would jump when typing usually back up into the middle of the text somewhere.
If this is similar, read on.
First, go to Dell's website, downlaod the latest driver for the Alps Touchpad: http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R113813&SystemID=LAT_PNT_PM_D600&servicetag=&os=WW1&osl=en&deviceid=2514&devlib=0&typecnt=0&vercnt=7&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=149404
Download the driver but do not install yet. Note, this is for a Dell Latitude D600, Windows XP. Vista may have a different driver.
Open Control Panel/Mouse/TouchPad Tab/Touch Sensitivity Button. Open Touch Sensitivity, adjust below the halfway point on the slider. Try different settings, you may also want to check the "Tap off when typing" box.
If you do not show these properties as above, you probably don't have the latest driver installed. In that case, install the driver you downloaded above then come back and refer to the instructions.
I spend 90% of my day on this D600 and really love it, not a speed demon, but light enought to carry with one hand and is a great email/browser machine as you probably already know!
Before installing tis driver
Apr 04, 2009 | Dell Latitude D600 Notebook
Compaq Keyboard Logo
122 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
