Question about Mercury P4VM800M7 Motherboard
Lan card my motherboard lan card not working
I lost my vga driver plz send me my vgadrivers
my mother board is E2140 MERCURY
Posted on Jun 30, 2008
One of Intel DP55kg Motherboard desktop shows 100 mbps Lan connection when the other desktop shows 1gbps. why?
It depends upon the make and model of the LAN card. The one in the Intel may be a 10/100Mbps LAN card and the other one a 1Gbps LAN card.
You cannot make a 10/100Mbps LAN card run any faster than it was designed for.
May 11, 2011 | Intel DP55WG Motherboard
I have a intel D915GAG MB will a nivdia 9400gt video card work in it? motherboard - 10/100 lan sku http://www.intel.com/support/motherboards/desktop/d915gag/sb/cs-012059.htm video card...
the card should work, however you wont get nearly the capibility of the card with that motherboard (as the card uses PCI 2.0 and the mobo only supports 1.0 speeds). So long story short, it will work, but the graphics card is a little overkill.
Hope this helps!
Thanks
Mike
May 17, 2010 | Intel D915GAG Socket 775 Motherboard -...
My lan card drivers are not working. I have Intel D101GGC Motherboard. Please help in that problem. As soon as possible..
1st you check the Lan card driver is properly Installed.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on the Network Adapter
  • See the Lan Card Driver.if it is not available then Install the Lan Card Driver.
  • You can install driver from this site Lan Card Driver
  • If Lan Card Driver is Install then check It is disable from the network places in the control panel.
Mar 05, 2010 | Intel D101GGC Motherboard
How to unactivate lan card p5gc-mx by jumper
I would see if you can disable the LAN card in the BIOS, as the LAN card your speaking of is part of the motherboard and not a removable part. I have disabled these before VIA the BIOS and then installed a third party LAN card in an available slot on the PC.
Jan 17, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Lan card
Use a different PCI slot and reinstall the drivers for your LAN card. If this does not fix the problem there may be a compatibility issue between the network card and some other software (eg. irq conflict etc.), or the LAn card may be slightly faulty and have problems on some motherboard.
In this case you can try troubleshooting the problem.
If you cannot find out the problem at a glance, checking in device properties, you may be forced to reinstall Windows. In this case I suggest to just replace the part. The Ethernet (LAN) pci card is quite an inexpensive part, and you can still use this one on a different computer.
Regards
Apr 02, 2008 | Gigabyte Slot 1 GA-6BXC Motherboard
Lan ports dont work
Where you able to check the Network adapter on the Windows Device manager?
How to verify your Network card is working properly
If you are unable to resolve the problem with your intergrated lancard then you can add additional LAN CARD on your computer or you can also buy USB to LAN CARD adapter.
http://www.techdeals.eu/electronics-store/images/tduc0205-1.jpg
Mar 07, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
After a BIOS flash 2nd LAN is not working
I would try this uninstall the lan card driver shut down the machine, remove the lan card from PC. start the machine let it strtup fully then close down the machine again and put back in the lan card and reinstall the driver.
Dec 09, 2007 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Mercury P4VM800M7 Motherboard Logo
114 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
