Solution #1
posted on Jun 28, 2008
TandN
Rank:
Wiz
Rating: 85%, 179 votes
This
is your best and complete answer. It should be rated as a fixya. Give
this person the fixya. You never said that you tried this but if you
follow the steps you will get a professional style installation.
Solution #2
posted on Jun 26, 2008
bestdarngood
Rank:
Guru
Rating: 87%, 148 votes
The
dashboard is easy to take off, there are screws on the bottom
underneath the dash holding it on and at the top are clips that should
pop off and if you are careful, they won't break. It should come off
from the driver side to the passenger side. The overhead console
should also have some basic screws holding it up, they should be able
to be removed and then you should be able to slide the wire above the
ceiling carpet, you may want to use a small metal rod to help push it.
To get to the wiring at the floor, the interior side panels can be
unscrewed, the screws may have plastic tabs covering them that you can
pop off, you should then be able to lift the carpet at the edges if any
wires run below it or if you want to run the wires below it. Let me
know if you have any questions and I will be glad to help
Comment by bestdarngood, posted on Jun 27, 2008May
I also add the wires running to the overhead can be run down the side
of the car by the front of the door under the plastic strip next to the
windshield. Let me know if you have any other questions with this
