To block and unblock TV programs and movies: 1 Press MENU and highlight the Locks menu icon. 2 Press DOWN to display the PIN code entering screen. 3 Enter your four-digit PIN code and press ENTER 4 Press DOWN to highlight Enable Rating Blocking. 5 Press RIGHT and DOWN to select On, and then press ENTER. 6 Press DOWN to highlight Edit Rating Limits and press ENTER. 7 Press ARROW KEYS and then press ENTER to select the level of blocking you prefer. A box with an "X" is a rating that will be blocked. As you highlight a rating, a definition for the rating appears at the bottom of the screen. 8 When done selecting the ratings you want to block, highlight Done and press ENTER To set the sleep timer using the remote control: Press SLEEP on the remote control to set the length of time until the TV turns off. Repeatedly press SLEEP to increase the time in 10-minute increments, or press UP or DOWN to increase or decrease the time in 10-minute increments, to a maximum of 180 minutes. .
Here is a link to the complete User Manual for your TV:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2841511&rpn=undefined&modelFilter=26HL66&selCategory=2797337&selFamily=2838040
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
RCA TVs come with a
child lock capability called V-Chip. It's a parental control system which
allows you to block programs and films by content, age-based ratings and the
ratings which come with the movies. The parental control is a code, sent by the
broadcaster to your television. The V-Chip will not work if the broadcaster doesn't
send the control, or if the parental controls are switched off or unlocked. The
controls are set up in the TV's main menu. The default is off.
Instructions
From
the main menu choose "Parental Controls;" it's option six.
Choose
the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK
button on the remote, scroll through until the TV-MA rating appears. Press the
right arrow button to move the highlight over to the "Status" field
and toggle to "View." Press the OK button. This will set the
age-based ratings to Mature.
From
the Parental Controls menu, select the second option, V-Chip Movie Ratings
Limit and change the rating to TV_MA and the "Status" to
"View."
From
the Parental Controls menu select the third option, V-Chip Unrated Program
Block and select item one, which will be "View."
Select
the fourth option, which is "Channel Block." Highlight the Channel
field and using the channel up and down buttons, go through and check they are
all set to 'View." Any set to "Block" will need to be toggled
back to View.
Lock the controls to activate the changes using item six on the
"Parental Controls" menu
