Question about Janome 2049LX Mechanical Sewing Machine
Needle Size. does anyone know what size the needle is. I broke mine a couple of days ago and I lost all the extras that it came w when i bought it.
I usually use Kenmore needles. I bought my machine through Sears and was told the needles were compatible. Otherwise I get the appropriate size for my fabric weight at JoAnn Fabric. As long as it has a flat back it will work fine.
Posted on Aug 16, 2008
What size needles fit a Rex 26-188 walking foot machine?
16x63 needle system, unless it's been retimed for something else. Suggest you might want to find the dull, bent up or otherwise still intact needle and show it to your industrial supplier or repair person, so they can check for you.
Needle system tells you about the length and timing distance of the needle: see, e.g.: http://designer-entrepreneurs.com/blog/illustrations/Singer_Needle.pdf Size tells you about the diameter of the needle: here's a suite of home sewing machine needles, all of the same needle system, but one of the photos shows a comparison of sizes:
http://www.picturetrail.com/sfx/album/view/17206792
Jan 18, 2014 | Brother XR-65t Mechanical Sewing Machine
Needle broke
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 18, 2012 | Singer Sewing Machines
With each stitch the machine makes a loud clacking noise and needle broke
Needle breaks
7. Machine could be out of time--needs to be checked at a repair
shop
Sep 10, 2012 | Brother Sewing Machines
Has anyone had an issue with the husqvarna 600e continuously breaking needles?
Needle breaks
7. machine could also be out of time
Aug 29, 2012 | Husqvarna Viking 1
My needle broke. I replaced it. Now when I lower the needle to grab the bobbin thread it is hitting something. I have taken the bobbin case out and put it back in but it still wont work. Any suggestions? ...
It sounds to me like you have replaced the broken needle with one that is too long (wrong size).Check your manual for the proper needle size and look through your collection, or head down to the local sewing shop and pick up a new pack of proper sized needles. Now if the needle you replaced the broken one with is the same size, you most likely didn't loosen the set screw up enough and therefore didn't slide the needle up far enough before locking it in. Double check this.
Good Luck!
Chris
Feb 09, 2011 | Singer Sewing Machines
I am sewing a quilt and my needle is in the right place but it keeps breaking. Please help. Also, the thread break often.
here are something you might check
upper thread breaks
1.top tension to tight
2.thread to thick or to fine for needle
3.needle not inserted correctly
4.thread caught on something-spool pin, tension area
5.needle damaged
6.needle thread is not threaded properly
Needle breaks
wrong size needle for fabric
also check for lint & pieces of broke needle under the needle plate
also the bobbin case area -take the bobbin & case out & check for pieces of broke needle
here is a tip about needle & thread
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 21, 2010 | Husqvarna Designer I
New Home My Lock 134D Serger. The right needles keeps breaking. Yesterday I realize it is hitting the pressure foot. I have changed out the needle (size 14) about 7 or 8 times now. I have adjusted the...
check to see if the presser foot is loose
check to see if the needle is in backwards
if the presser foot is tight & needle is not in backwards then it could be a timming problem, since you said the needle is hitting the presser foot
please rate this with the thumbs in upper right hand corner
Aug 08, 2010 | Janome MyLock 634D Mechanical Sewing...
Singer Futura 250E - thread is shredding after 5-6 stitches
no damage to the machine yet
check the thread size you are using as you may have to use a needle with a bigger eye
thread is made by winding the material around and around then using a product to hold the material ends together
as a result thread will not last indefinitely and will break easily
you may have to use only thread from manufacturers that you know make good thread
Apr 03, 2017 | Singer CE-200 Quantum Futura Computerized...
Thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Dec 16, 2008 | Simplicity American Denim SA1100...
Needle Borke and cannot take out!
There are small holes on the metal block where the needles insert.  These holes fit hex/allen wrenches (I'm not sure the size).  Turn the wrench to the left to loosen, and the broken needle should either fall out or be loose enough to pull out.
Aug 19, 2007 | White Sewing Speedylock 1600 Mechanical...
Janome 2049LX Mechanical Sewing Machine Logo
117 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
