I have an aspire 4741z laptop with windows 7 os. and i can not connect to internet. when i checked my device manager, i do not have ethernet and network controllers. what driver do i have to install?
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Attach a Ethernet cable to the laptop, Open Device Manager, Network Adapters, Uninstall the Wireless adapter, reboot, Allow the software to apply the generic driver, try to connect to wireless network. Post results.
Download the LAN and device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: - http://www.acersupport.com/drivers_download.aspx
As of the moment there is no driver support for the Acer Aspire 4315. If you have already installed Windows 7 and you can connect to a cable internet through your Ethernet Port, you can try downloading and install Driver Genius Professional which can assist you in getting the compatible driver. Since this software can detect even unknown devices.
windows 7 automatically install all the drivers in case it had missed the driver kindly download the driver from friend system or internet cafe on your usb drive. there is link to download drivers for Ethernet. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
once your your online go to computer management > drivers and right click on WIFI card and click on update drivers it will download the drivers and install the drivers.
check your lan driver if you are using cable. right click on my computer select properties select hardware then device manager check network adapters the device must be enabled or driver is present. lastly check your cable or use other cable.
I would think you should be able to find all driver downloads on the Sony support site that pertain to your particular system. Most ethernet cards have a basic driver in the Windows OS (XP and above). You could try selecting the ethernet device in Device Manager, then properties and install from that point. Once you get on the internet, you can see if there is an update for it.
