Question about Proscan Televison & Video
I have a proscan ps57660 rear projection tv, and the picture tube keeps jumping. its like the colors won't line up. every so often it will hold, but that is only when there is a full moon and martians have landed on the white house lawn!!! last time i checked, the tv repair guy said i needed 3 seperate picture "tubes" and they would run me about $300.00 a piece, which is almost the cost of the TV when purchased new. any suggestions?????
  • lmcfa Jun 28, 2008
    thanks!!! i had a feeling that the $1200.00 we paid would eventually go right down the tube, literally. you know i have a mitsubishi 27 inch and its about 10 years older than the proscan , and i gotta tell you, the set works great, no problems, even remote works better than proscan. what was proscan/rca thinking when they made these tv's??? what a bunch of suckers we all were for buying them!!!! looks like sony and mitsubishi will be getting my money from now on!!! at least they have good warantees!!!!
    Scholar:
  • 104 Answers
TV repair guy is right. There are three separate tubes inside your tv (red, blue and green) that are set up to project perfectly on top of each other so that their pictures line up exactly. These tv's have shorter lives do to the fact that they are using the same technology as a conventional tv but they have seriously cranked the power up on these things. They run hotter and harder than any other tv out there. I recomend thinking fondly of the happy days that you had with this tv, then giving it a proper burial and upgrading to HD.
Posted on Jun 28, 2008
  • Chris Lyon
    Chris Lyon Jun 28, 2008
    Unfortunately, it was just a matter of the fact that it was the best and most economical technology available to accomplish that task at that time. Lots of other companies, including Sony and Mitsubishi used the same technology. Like many things in the tech world, it came, it was improved upon, and it passed.
Flash focus can no longer line up all colors,and gren is the one always sticking out;do I need to replace all my "color lamps"?
No,this tv have no projection lamp,tv only have 3 CRTS tubes guns R,G,B.Ur tv have a problems known convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike.The tv convergence board is dead.Tv convergence board,must be replace 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 17, 2011 | Sony KP-48S75 48" Rear Projection...
Hi I currently own a Hitachi rear projection . And I was trying to tune he color and I think I burned the tube I have a line onbrhe screen. Is there a way to clean the picture tube or replace it
Tv colors lines R,G.B mis alignment,colors shadows pictures or 3D pictures?Yes,this tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved the convergence board problems.Will solved the picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 15, 2010 | Hitachi 53SBX59B 53" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Blank screen audio ok. Picture tube has a line only going up and down
adjust voltage G2 Screen. thats why have retrace line. resolder also CRT board.
May 31, 2009 | Proscan PS50700 50" Rear Projection...
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The colors on my tv will not line up
You need a professional to align the convergence. it's a big job if one or more tubes have been replaced.
Apr 09, 2009 | Proscan PS50700 50" Rear Projection...
How to remove front screen on proscan projection tv model 50700
the front trim pops off and behind that there are screws that hold the glass in place. once you remove the screws you can access the screen and clean the tubes.
Feb 23, 2009 | Proscan PS50700 50" Rear Projection...
36" RCA Proscan TV no picture
LINE ACROSS THE MIDDLE IS THE VERTICLE CIRCUIT--COULD BE A LOOSE CONNECTION-TRY TO TAP GENTLY ON TOP OF SET AND SEE IF YOU SEE THE PICTURE ACTUALLY JUMP TO FULL RASTER,,IF SO LOOSE CONNECTIONS IN VERTICLE CIRCUIT---THE OTHER PROBLEMS WOULD BE ACTUALLY PARTS BAD IN CIRCUIT --IC,CAPS ETC... TUNICA
Oct 21, 2008 | RCA P52926 52" Rear Projection Television
Sony rear projection
My dad has a sony rear projection tv and had this same problem. A shop had to replace one of the color tubes(?) (green, red, or blue) had to be replaced. The shop said this was common with Sony rear projection TV's.
Dec 11, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
232 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
