The thermostat of my x5 is burnt. the machine is out of warranty. I want to try to fix the thermostat by replacing the burnt electric components. Is it possible ? I just need to find the correct components. Any suggestions? Is anybody available to send me or post somewhere a hight quality picture of the thermostat so i can read the specifications of the missing components?
if you didn't already catapult your X5 onto the nearest expressway, send me your email address & I will see if I can send you a photo - this site limits to 150K and I don't think that will cut it.
Spants/808pants - espressinator[at]gmail[dot]calm
Was this helpful?
Yes
No
Solution #2
posted on Sep 01, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
thank you Spants, I actually see that my t'stat is burnt. I agree with you : "there's no way in hell I'm sending this machine across the world to factory service"
Have you actually seen that your t'stat is burnt, or is the machine just acting like it is? If not, check. I found that my heating element had corroded through. Unbelievably, this doesn't result in immediate failure, nor death, etc, though it sure ain't what UL might have hoped for - and it acts like a busted t'stat. The machine will keep heating, though irregularly, completely ignoring any switching in the thermostat, being regulated only by a crappy snap-disc "catastrophe-preventer" switch. The t'stat is set up for some lame reason only to switch the neutral side, flying in the face of basic safety in electrical design. The corroded-through element seeks a ground, right through the boiler water, through the case ground, and (assuming you have a working three-wire electrical system) you won't know the difference, as long as you don't let your boiler run dry...though your electrician might be in for a little surprise elsewhere in your house if he opens that ground-line while your machine is on. I'm now trying to match up the element with something close, since there's no way in hell I'm sending this machine across the world to factory service.
i need to replace the power switch on my x5, it looks like i can access it through the top,i see a...
(More)
i need to replace the power switch on my x5, it looks like i can access it through the top,i see a bolt behind the clock and a screw on the back, is this what i need to remove to get in?
I was preparing coffee today morning when all of a sudden there were sparks from the machine. After...
(More)
I was preparing coffee today morning when all of a sudden there were sparks from the machine. After seeing the sparks I turned off the machine and restarted it. However, now the coffee flows out of it but it is not heated. What do you think is the problem? How much will the replacement part cost?
FrancisFrancis X1 3 years old. Since this week (water in reservoir is clear) when I switch on the...
(More)
FrancisFrancis X1 3 years old. Since this week (water in reservoir is clear) when I switch on the pump without coffee in the basket water runs out light brown? I have to pull through about 3 cups to get clear water each day before make a coffee?
My steam valve won't close fully. Maybe it needs a new valve seat, or a whole new valve? Should I...
(More)
My steam valve won't close fully. Maybe it needs a new valve seat, or a whole new valve? Should I search for a replacement part or is there a way to fix it? Where can I buy replacement parts? Thx.
WHy is the steam knob made of plastic?The steam valve is metal and it ate plastic grooves on the...
(More)
WHy is the steam knob made of plastic?The steam valve is metal and it ate plastic grooves on the knob.Where to find metal steam knob?
