Question about Cameras
Canon 430 EX flash problem
The flash did not work perfectly.
No matter you set it to fully manual at your Canon 40D or
to P mode the outcomes were not stable.
the distance was around 2 to 4 meters and the manual setting was
F5.6, 1/60 secs and the ISO was set to auto.
According the shooting record, Canon set the ISO to 400.
- Some with perfect exposures
- Some terribly under exposed
- Some terribyly over exposed.
Can you help please?
Albechao
  • 3 Answers
Were you indoors? if so, take the ISO of AUTO and out it on 400. Leave the camera set like you had it, Manual 1/60 @ 5.6. Do notuse evaluative metering. Use single spot metering or the smallest center weight setting.
Posted on Jul 17, 2008
Flash speedlite 420 ex not works well with canon 7d
What are the issues your having? Without an idea of what the photos look like and what settings you are using there's not much help we can offer.
Apr 09, 2014 | Canon Speedlite 420ex Flash For Xt Xti Xsi...
Overexposing in auto modes, low light being reported.
The Auto modes on the 40D weren't very reliable when I ran comparison tests with other models..and systems. In fact I gave up with the 40D altogether! :) The anti-aliasing filter was a joke and the auto focus was....blaaah.
You mentioned you 'reset everything'? Yet it sounds like there may be some residual settings left behind. EG, white balance settings, flash sync speed. You might also want to check the individual presets for LANDSCAPE, PORTRAIT, NATURAL etc... Once you can start afresh, things should start to make sense as you make adjustments. Just remember to keep account of what adjustments you make.
CF (custom functions): are normally reset to factory however some settings remain (white balance adjustments, tonal adjustments etc)
Nov 25, 2013 | Canon EOS 40D Digital Camera
I have been using my Canon 580ex ii with my Canon 5d mark ii. It will not fire at all now. I also tried my old 420 ex speedlite and it will not fire either. But, they both work on my Canon 40d.
You can actually set the external flash not to fire in the menu settings of your camera. Check there or try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Oct 08, 2012 | Canon Speedlite 580EX II TTL Flash
I have a canon 40D and a speedlite 580 second sync not working
If you are not in P, AV, TV or M then the camera will not allow that feature. The picture modes disable many higher, more sophistocated features.
Jan 31, 2010 | Canon SPEEDLITE 580EX TTL Flash
My xti fell with the 430 ex II attached now it
The hot shoe was bent slightly causing the flash contacts to not touch those of the camera. By using a socket from a socket wrench set, place it over the grids of the hot shoe and tap firmly with a hammer to straighten it.
Jan 02, 2010 | Canon Speedlite 430EX TTL Flash
Green pics in Modes M and TV
Check and see what type of lighting is selected. (Tungsten etc.) Adjust and see if that makes a difference.
Jun 17, 2009 | Canon EOS 40D Digital Camera
Photos are super over exposed when using 430 Speedlite w/Canon 40D, even though the settings are per the manual
if overexposed, what yuou can try and do is make the shutter speed faster (so less light reaches the sensor) or reduce to the ISO setting to 200 or lower as needed. Both these will help with overexposed images. I wouldn't recommend consulting the manual because there are so many variables... The manual doesn't know exactly how much light there will be in very shot you take, and that is the crux of photography, working out what settings work best with the light available for each shot.
Hope that helps!
Apr 06, 2009 | Canon EOS 40D Digital Camera
Canon Speedlite 580 EX II
is your master flash set on a camera? The EX II has something that makes it have a 1 second delay when using sync mode, unless the master flash is set on the camera.
Dec 27, 2008 | Canon Speedlite 540EZ TTL Flash
Exposure problem
Your 40D requires that you use an ETTL-II type flash like the Canon 380-EX. What flash are you using?
Mar 25, 2008 | Canon EOS 40D Digital Camera
Cameras Logo
441 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
