Question about Pinnacle Dazzle DVD Recorder
Not Recording When i get to the start recording. the tab will not lite up so i can click it to start the recording. I have ruined 3 new dvd's trying. How can i get it to record?
  • marci32 Jul 23, 2008
    When I click on record now, it just sits there. I do not know what I am doing wrong, can you give me step by step instructions?
  • mxz96942 Sep 04, 2008
    The start recording button won't lit up. Message on top of the box says "please wait,...analyzing the disc...". A timer is also displayed and keeps running. Sometimes my pc freezes up. What seems to be the problem?
  • 27 Answers
Try to go back to step number select video source please click the box and select the dazzle not pinnacle file capture. Try it again.
Posted on Mar 09, 2009
Make sure your not using blank CDs. you have to go to the electronic store and bt specific recording dvds. your probably using the wrong ones. hope i helped
Posted on Mar 30, 2009
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
Everything shows up as working fine and drive can write DVDs, but has never been able to write cds, it says all was successful, but when disc is removed it is blank. i have had drive replaced before for...
Try double click My computer than right click the drive you want than properties than recording tab and make sure that Enable CD recording to his drive is checked. If you have two CD-R drives only one can be enabled to record at a time.
Feb 15, 2010 | Lite On LiteOn LH-20A1P - Disk drive -...
My drive will regognize and burn cds but when i try to watch or burn a dvd it says unkown or invalid its an hp dvd writer 420n
install the corect hp drivers and check the windows settings to make sure it is not sean as a cd drive instead of a dvd
Aug 03, 2009 | TDK Indi DVD 420N (AID+420N) DVD+RW Burner
Losing Audio Halfway Through Recording
The audio failure sounds more like a VHS player failure than a DVD software/recorder failure. Both audio and video are transferred at the same time to the DVD, and as long as the DVD recorder is working, that's really all there is. I would check the VHS player and confirm that the sound actually works all the way through.
Mar 02, 2017 | Pinnacle Dazzle DVD Recorder
Speakers
I suggest that you check and ensure that the correct playback and recording device is selected in the sound properties of your system. Please refer to the steps below as a reference.
1. Click on Start > Control Panel.
2. In Control Panel click on classic view, located at the side bar.
3. Next double click on ‘Sound’ and go to ‘Playback’ tab.
4. Please ensure that under ‘Playback’ tab; the headset is selected as default device.
5. Next go to ‘Recording’ tab and ensure that the microphone of the headset is selected as default device.
6. Now, try to take a test recording using Sound recorder.
7. Click on Start > All Programs > Accessories > Sound recorder
8. Take a test recording with Sound recording using the microphone of the webcam. Then playback the recording and check whether it was recorded clearly.
Jan 11, 2009 | Dell Inspiron B130 Notebook
I have a Lite-On LH20A1P dvd drive. The problem is, it starts to write and the about a minute later it kicks out the disk saying - could not perform end of Disc-at-once. Then burn process failed. Could...
-There a lot of things we may consider.I'll give some few things.
-It may be your dvd drive is not working properly.
-It maybe the setting of your dvd drive is not configure properly.
-It maybe the blank disc is having the issue not the dvd drive.
follow this steps to check and troubleshot:
-Set the dvd region
right click on my computer select properties, go to device manager click the + sign under dvd drive, right click on you dvd drive-choose dvd region.
-Enabling CD recording
Click on My Computer-right click on dvd cdrom drive-go to properties-select recording, then check if the Enable CD recording has a check on its box, then check the box that says Automatically eject the CD after writing.
If this steps will not work then send me feedback so we can move on to the next level of troubleshooting.
Oct 12, 2008 | Lite On Computers & Internet
CD Burning gets stuck
Try this: : Decreasing the burn speed If the drive is not recognizing the disc at all, skip to Step 4. Decrease the CD writer's burn speed by half to increase the likelihood of a successful burn. Decreasing the burn speed is a quick, easy way of increasing successful disc burning sessions, at the expense of taking more time to create a disc. The following steps are for Windows XP only. For Windows 98 and Me, decrease the write speed from within the software that you are using to write discs (RecordNow, Easy CD Creator)
  1. Click Start , and then My Computer .
  2. Right-click the drive icon, and select Properties .
  3. Select the Recording tab and reduce the Current Write Speed by half (for example, from 16x to 8x).
  4. Click OK and close the My Computer window. Try burning a CD. If the drive fails to create the CD, go to the next step.
Step 4: Setting up disc recording in Windows XP If the computer does not have Windows XP, skip to Step 6. If you are using Windows XP, use the following steps to ensure that native burning is enabled:
  1. Place a blank disc into the drive. NOTE: If the error <drive letter> is not accessible. Incorrect function. " opens, close it and continue using these steps to correct this problem.
  2. Click Start , and then My Computer .
  3. Right-click the writable drive icon, and select Properties .
  4. If a Recording tab is shown, select the Recording tab, select Enable CD recording on this drive , and then click OK . Try burning a disc again. Continue to the next Step if you are unable to burn a disc. If a recording tab is not shown, continue using these steps. Figure 2: Enable CD recording on this drive c00368150.gif
  5. Look for a Recording tab: If the Recording tab is not shown, Windows XP has not detected the drive as a recordable device. Use the following sub steps to enable the Recording tab:
    1. Click Start , Run , and type regedit in the Open field.
    2. Backup the registry: Select My Computer from the list, click File , Export , type a name that you will remember, and click Save .
    3. Click OK , and browse to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
    4. Click the Volume key that matches the CD/DVD drive that is capable of writing discs. If only one drive is installed, one volume key is listed. If you have more than one drive, examine the data values (by double-clicking them in the right pane) to find the correct drive.
    5. With the volume key selected in the left pane, double-click the Drive Type value in the right-pane. Figure 3: Drive Type registry value (CDRW) c01367502.jpg
    6. Type the number 1 in the Value Data field if the drive is capable of recording to CDRW discs (including CD-R discs). Type a 2 if the drive cannot write to CDRW discs but can burn CD-R discs. NOTE: A value of 3 indicates that the drive is only capable of reading discs. Changing this value to a 1 or 2 enables Windows to view the drive as a recordable drive.
    7. Click OK , and close Registry Editor.
Jun 20, 2008 | Dell Dimension 4700 PC Desktop
LiteOn-SHW-1635S
Hello all, I have a LiteOn SHW-1635S IDE DVD/CD burner running on Microsoft XP Media Center OS with firmware version YS0Z Driver version 5.12535.0 The Hardware is Gateway GT 5058 approx 2 yrs old For some reason, this drive will not recongnize ANY rd-r media of any kind . I have tried the flashes.
Apr 10, 2008 | Lite On (SHW-1635S) DVD RW Dual Layer...
Lite On disc writing failure
try updating the rom by downloading from lite-0n
Mar 27, 2008 | Lite On LVW-5006 DVD Recorder
Dvd
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer Goodluck!
Mar 25, 2006 | Lite On LTC-48161H-18 CD-RW Burner
Pinnacle Dazzle DVD Recorder Logo
167 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
