Question about Dirt Devil M086700 Vision Bagless Upright Vacuum
Missing part on motor shaft?
I've been replacing the belts on my Dirt Devil Vision Wide Glide Vacuum R086700 only to have them wear out prematurely. After taking a really close look, I discovered that the motor shaft was bare metal. Is that suppose to be the case? If not, what is the part that should be and how do I find it.
  • bearsfan50 Dec 19, 2008
    I have the same problem. I can't find my manual and I can't find one on line to see if it's supposed to be a metal rod or some plastic caster on it to protect the belt.
  • 281 Answers
The reason the belts are burning up so quickly is the old rubber from the other belts is still on the motor shaft.clean the shaft down to the polished finish then put on a new belt.make sure your brush roller turns freely .thats the other possiblity.the brush roller might be bad.sometimes hair and dirt get twisted around the ends and keeps it from turning
Posted on Apr 04, 2009
  • PETE GALATI
    PETE GALATI Apr 04, 2009
    the shaf is supposed to be bare concentrait on the brush roller might have a lot of hair or carpet strands wrapped around the ends.if so remove the hair and carpet strands
I have a dirt devil vision wide glide, 086700, made may 2006. I found 2 places with reasonable prices and the same excellent explosion diagrams. www.ereplacementparts.com and www.vacpartswarehouse.com hope...
Do you know how to get the height adjustment knob to release the wheel height? Its stuck on high carpet? The knob moves but doesn't change the position?? Identical Vacuum.
Feb 27, 2011 | Dirt Devil M086700 Vision Bagless Upright...
The belt keeps slipping off. I bought a new one and it too slips off after about a half hour of vacuuming.
check the motor shaft for loosness. when the bearings wear out and fail, the motor shaft will not be strait and the belt will ride off. also check for alignment and inspect the brushroll for proper installation, free rotation, and non melted endcaps. let me know if you have any questions
Jan 05, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
HOW DO YOU CHANGE THE BELT ON A DIRT DEVIL VISION VACUUM CLEANER?
With the vacuum unplugged, turn the machine beater bar side up. Locate the clips or screws that hold the plate over the beater bar and remove the plate. The beater bar sits in sockets just inside. Be careful in removing it; take your time and note how it comes out...this will make reassembly easier. Clean the debris while you have tha bar off and remove any debris thet you see in the vacuum hose area behind the bar....The new belt slips over the motor shaft behind the beater bar (further up in the cavity behind the b/b), then you slip it back onto the beater bar as you place the bar back nto the sockets. Test your work by revolving the bar a bit to make sure that everything is back in place. Replace the plate.
Regards,
--W/D--
Jul 12, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Roller on my dirt devil vision not spinning
how do you replace a belt no.5 on a dirt devil vision.
Jan 31, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt Devil M086700 Vision Bagless Upright Vacuum Logo
189 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
