Question about Samsung Televison & Video
The recording mode will not change from fr and any recording i set to more than 1.5 hrs will not record fully
    Genius:
  • 1,665 Answers
What is your model no
Posted on Jun 28, 2008
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Dvd recorder
The following should give you access to a service menu containing controls for macro-vision and region coding. You can change the regional settings from there.
1. Set your player to Standby
2. Press Title, Clear and Power
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Change VCR settings from SP to LP or EP
Hi;
I have a Panasonic VCR with a different, but I know how to 'fix' your problem on my m/c. The remote for my m/c has a "REC MODE" button; operating that button changes from SP to EP etc. Check it with the "Program" button on your TV screen.
harrisonmx3
Apr 27, 2009 | Panasonic Televison & Video
Copy recorded pgms off DVD HDD to DVD+RW
the manual specifies that if you select for recording the FR mode the machine automatically adjusts the recording mode for the program to fit on a 4.7G dvd. If you use a dvd DL if will auto detect that you have this type of dvd and the FR mode will automatically allow you to make full use of the available space. Depending on the space needed on the dvd the picture quality will be good to excellent (refer in the manual to Recording Modes..)
Aug 30, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Only records 1.5hrs of FM radio.
mine usually needs me to stop it at the point I want to end it. that probably doesn't help you any, but see if you can work from there.
May 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Recording from the hard drive
you have to choos the sp mode which is over 2 hours in recording. i noticed that after you set it in sp mode and you press the record button on the recorder panel more than once, the recording time changes.
Feb 25, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Using FRec to record on DVD-which mode does it record in?
You seem to have fixed your own problem. Yes, the Flexible recording function only works on scheduled recordings. However, you should be able to do direct recording with FR - but when you press the F.Rec button for a direct recording a notification should come up on-screen asking you the amount of time to record. This is on page 16 in the manual. If you started the recording without being on the correct input for the DVD recorder on the TV, you would not have seen this message and the unit would default to EP 6 or 8hr. (based on settings).
Obviously the FR swaps between bit-rates to fill the disc completely, so you would see the recording tracks had almost completely filled the disc when done.
Also, some older DVD players, even if the disc type is compatible and finalized, do not read VBR recorded DVDs - so that my be another issue.
Hope this helps.
Feb 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Viewing
you have to finalize the disc first.once it is finalized you can not record any more material on it,so make sure you record everything you want on a disc. you can maximize disc space by changing speeds on the dvd recorder. for example: if you have 5 hrs of stuff on a tape, set the dvd recorder for 6 hrs or more recording time.the quality should be ok [depends on how good of quality you want] if you set the speed for 2 hrs, your quality would be better, but obviously everything won't fit.
hope this helps
wg
Jan 30, 2008 | Zenith XBR413 DVD Recorder
Recording time
put the machine in dvd mode and press the rec mode button on the remote(right next to the rec button on the bottom) hit the button until you get to the desired mode. i just changed mine and i am copying now from vhs to dvd and it did say it is recording in ep mode, so fingers crossed!
Nov 19, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
20 people viewed this question
Henry  Thomas
Henry Thomas
