Question about Black & Decker String Trimmer Cordless 12" 18V
Line doesn't advance
If it is the small white lever, where can I get another?
  • Anonymous Jul 04, 2008
    How does one replace the small white lever on the grass hog (i have just bought one). Thanks
    Champion:
  • 313 Answers
Should be available at your B&D service center inyour area
Posted on Jul 03, 2008
  • mr aicnelav Jul 06, 2008
    pull the lever by plier gently & install the new parts same way as the old parts.
I have an old Dymo Jet 1855 Mk11 and the tape will not advance when embossing or cutting
I was having the same problem. When you load the tape make sure to push it through the slot just in line with the white lever that sticks out of the left side of the machine.
Jan 12, 2014 | Dymo LetraTAG Thermal Label Printer
Minolta xd7 slr
Did you impact the top cover? Spill something on the advance lever?Try putting some Windex on a toothbrush and cleaning around the advance lever and see if that frees it up
Sep 21, 2013 | Photography
Kodak carousel 650h will not advance or go back. Not mechanically jammed. Doesn't respond to buttons either on main housing or from remote. Select button, fan and lamp all ok.
If the select button functions correctly, then it sounds like you have a wire broken or a wire nut that holds a bundle of wires together has fallen off. If it was the solenoid link, then the Select function would not work. After removing the bottom cover, look for the orange wires, That is the cycle circuit. Look for a broken or unattached orange wire from the side button and the remote receptacle.
The other possibility is that the direction lever is stuck, bound up or the direction lever spring is broken. The attached image of the top plate of the slide change mechanism will show you the end of the direction lever. It should move freely, up & down on its center pivot. You should see a small, wire spring, about 2-3 inches long on the lever. If the spring is not there, or the lever does not move freely, that may be the cause of no forward or reverse.
Feb 08, 2013 | Office Equipment & Supplies
I have a 98 mustang and the air only blows thru the defroster, i checked blower motor, i checked vents, all that looks fine and works but ac will not blow thru vents. i checked firewall where ac lines run...
A lot of vehicles have the heater controls ran by vacuum. Just because the lever moves doesn’t mean the flap inside is. Check for broken vacuum lines to heater.
Oct 15, 2017 | Cars & Trucks
How do you hook up a sharp stereo cassette deck RT-W800
If that tape deck of yours has an audio line out jack (like the RCA red & white holes, usually located at the back), get an RCA plug to connect it to your stereo receiver's line in jack..... or
if that tape deck of yours doesn't have an audio line out jack but, instead, has phones (or headphones) jack (usually located at the side or front of the unit), then get a plug to connect it to your receiver's audio line in jack (RCA type, also coloured red & white).. Usually the plug is small so you may have to use an adapter for your tape deck's phones jack.
BOB (June 23rd '12 3:45am)
Apr 28, 2012 | Audio Players & Recorders
MODEL 760h WILL NO LONGER ADVANCE SLIDES
The KODAK Carousel 760H was manufactured approximately between 1971 & 1981.
The problem you are describing is most likely a broken cycle solenoid "link". This "link" connects the cycle solenoid and the slide change mechanism. Repair parts are still available, but this is a repair best left to a factory-trained technician. Contact an Authorized Repair Dealer.
Jul 25, 2010 | Kodak Carousel 4400 Slide Projector
Replaced line spool and it will not feed.
Under the line spool u are going to see a small lever it coud be white or black, is plastic, and it moves. u need to replace that is easy and cheap. call ur nearest Black and Decker servicenter to get it. is a pull and push fix.
Sep 22, 2009 | Black & Decker 14" Grass Hog Xp...
My film advance lever will not advance
First check for corrosion on the two battery contacts, and that the lower contact is still spring loaded and moves. Be sure you have a good battery by inserting it and checking with the battery test button by the rewind knob. If the lights and meter needle are working you're getting power. Remove the bottom cover and you'll see an electromagnet under a whitish plastic cover at the rewind end of the camera. Pull the magnet away from the coil by rotating the L shaped metal lever - you don't have to remove the white cover. Sometimes the magnet gets sticky. That should release the shutter. If it's really dirty, it might stick again. Be careful if you remove the white plastic since the magnet has fine wires that are easily broken, but you can clean the magnet interface.
May 30, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film advance
I removed the advance lever cover as suggested and tightened the screw. This did not solve the issue. However, I then realized the film rewind button on the bottom of the camera was stuck on the "in" position. I could not get it to release which meant I could not advance the film lever to free up the shutter. To solve this issue I removed the bottom cover from the camera (taking out the 3 small screws) and then pulled the advance lever button all the way to the right. This released the button that had been stuck in and allowed me to advance the film lever properly again and take more pictures. Hope this helps!
Jul 14, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Black & Decker String Trimmer Cordless 12" 18V Logo
44 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
