Question about Cameras
Built-In Flash I'm only 17 and am somehow tech. impaired. I just bought a $20 starter digital camera, it even came with a Dummies guide. So far, it's been what I expected for the price. Not the greatest quality picture, but it came with a program to make the picture look better on the computer(hehe). Anyways...my concern is the built-in flash. Now this may sound dumb, but is that automatically always on? Is there a way to turn it off? Whenever I take a picture with an extra light on, it turns the whole pic white. That's a little overkill for flash I think. I tried putting tape over the flash but then the color's distorted. Is my cheapy walmart camera hopeless in taking a worth-while photo? Or is there something I can do? Please and thank you. I don't know what my product brand name or anything is, I just know it is a 2.1MP Digital Camera for Dummies(Title on packaging) and "Sakar" is on the packaging as well. I don't know....
  • John Hannah
    John Hannah May 11, 2010
    hi Jess. What is the extra light you are talking about. Are the pictures OK without bthe extra light?
  • 77 Answers
Whether of not your camera has different flash settings really depends on the camera. the best solution is to carefully read the manual that came with the camera...
Posted on Jun 14, 2009
I bought a camera from a friend, Olympus e-420. but when i started to use it, i always got dark picture even the flash is already switched on. i'm thinking the built-in flash is delayed, do i have way to...
There are multiple reazons for the picture to look dark, a very short exposure, or a low flash intensity.
Try changing the flash intensity, this is done by pressing the Exposure compensation and flash button simultaneously.
Or playing with the exposure settings to see if there is any difference.
Concerning the ORF file format, this is this camera's RAW format, it's usefull to proffesionals, but for the common user, JPEG is the best option. As far as I know, this camera records both formats simultaneously.
For future refferences, here is the user manual : http://www.olympusamerica.com/files/oima_cckb/E-420_Instruction_Manual_EN.pdf
Mar 17, 2011 | Olympus E-420 Digital Camera
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Flash works but lighting in pictures poor even when outdoors - occurs while in auto
How far away are your subjects? the built in flash on most cameras is always underpowered.
Jun 13, 2009 | Canon PowerShot EOS D60 Digital Camera
Can't take good pictures with new Canon Rebel xsi
You will need to read the manual. I f you have a basic understanding of how ISO, shutterspeed & Aperture width combine to determine the 'right exposure.
Try this:
Set the camera to Av (aperture priority mode). Half press the shutter button and see the light meter indicator to see how well exposed your shot will be. For most cases you would be aiming for a value of 0 (properly exposed). The metering mode determines what part of the frame is used to compute the correct amount of light. For starters begin with pattern metering. Try and aim for a shutter speed of 1/125 or more if you are using the 17-55 mm EF-S f3/5-f5.6. Try and shoot at 40 mm F/5.6 (in Av mode this can be set by rotating the dial near the shutter button.
All the best
Mar 29, 2009 | Canon EOS Rebel XSi Digital Camera
My powershot G9 built in flash is not working
There is a switch on the hot shoe to detect the external flash. When you use an external flash, the switch will be pressed down, then the unit will bypass the internal flash and won’t let it fire. If the little switch gets stuck somehow, you won’t get your internal flash on.
Check this switch on the hot shoe (either on the left side or the right side), blow some compressed air then plug/unplug an external flash several times. Hopefully you can get it back
Feb 06, 2009 | Canon PowerShot G9 Digital Camera
Nikon D100 SLR Built in Flash Repair
allisonsylvi,
That's hard to answer until it is seen by the repair person, a reputable repair shop might be able to cannibalize another camera for the pop up flash parts pretty cheap and you just have to pay his hourly rate (the big variable). If the camera still functions otherwise and even the pop-up flash still works, you may want to go low-tech and hold it down with black electricians tape. You can turn off the flash so it won't want to pop up even in low light situations. If you use a flash attachment it will produce better results anyway. The D100 is a tough camera, lots of photojournalists were the first to embrace it for its durability out in the field. (metal body as opposed to plastic parts)
randy320sgi
Jan 07, 2009 | Nikon D100 Digital Camera
Camera flash problem (Nikon)
ok,
try to set the menu item for Auto FP to ON (it works in P,S, A, and M modes only) that will activate the Highspeed Sync when you are using the SB-600 flash unit, set the flash mode so the indicator shows the off position (the line thru the lightning bolt symbol) on the top inidcator menu in the its next to the red eye redution icon that will keep the built-in flash off even if you need it in low light. hope that works for you.
randy320sgi
Jan 07, 2009 | Nikon Cameras
Flash does not activate
I had this same problem on my pro1. I went and bought an external flash so that I would have a flash at least, when I mounted the flash and fired it a couple of times all of a sudden my built in flash popped up. haven't had an issue since.
Hope this helps
Dec 12, 2008 | Canon PowerShot S3 IS Digital Camera
Settings that must be set before... the external flash feature
Yes, set the camera mode dial to P, A/S/M or any shooting mode except the movie mode. Turn on the extension flash unit's power then select the camera's flash mode. The flash mode button on the camera controls the built-in flash as well as the extension flash. Only the built-in flash and the Olympus FL-20/FL-40/FL-50 extension flash can use the red-eye reduction flash mode. All flash units can use the fill flash, flash off, and slow-sync flash modes.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Cameras Logo
59 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
