My little Behringer Eurorack MXB1002 had the power supply cable ripped out and the chassis DC chassis connector w broken. Does any one know where I can get this part tro repair it?
  • Ronald Wingfield
    Ronald Wingfield Feb 17, 2009
    I HAVE NO POWER CORD, WERE DO I GET ONE?
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi audi-op
    Behringer are pretty good themselves for supply of spare parts. Where in the world are you and I can find the right people to talk to for you.
    regards
    robotek
  • 1,512 Answers
No worries mate.Good to hear
robotek
Posted on Jun 29, 2008
DBM Pro Audio in New York has all the Behringer parts. I was able to get parts there. Thank you all for the support.
Posted on Jun 28, 2008
Behringer eurorack mx 1604a
36V center tapped plus 48V phantom power, this is, 18-0-18VAC plus 0-48VAC transformer, this should be the correct voltages...
Sep 20, 2013 | Behringer Music
Behringer ub802 mixer is buzzing even when no input when i hook my head phones into the headphone jack and main output jack
If it buzzes when you have no inputs AND no output leads connected, there is a problem with the power supply... HOWEVER if you have used UNBALANCED output cables instead of the REQUIRED TRS BALANCED output cables, it is possible the noise is being driven backwards and that is what you are hearing. Note that at full gains, there often is a tiny bit of noise, usually hiss. Also make sure the supply is powered from the SAME receptacle as the equipment this drives such as an amp or powered speakers.
Jul 18, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Jun 10, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Behringerbx4500h amp has a bad hum i here the have this problem
If the hum exists with NO input cable plugged in, this requires repair, most likely in a shop familiar with the unit.
The problem may be in the unit's power supply or a broken connection inside.
This problem can also happen if one of the oputput amp transistors shorts driving out DC current into the speaker which is a grave risk to the speaker. Check the DC out of the speaker connector. If it is NOT very near zero, say less than 0.1 volts DC, do NOT copnnect speakers..
Jul 13, 2010 | Behringer Bx4500h Ultrabass 450w Bass...
Need Behringer Eurorack mixer power supply connector
Those were used for mic connectors at one time,,, they are related to the Amp 91-MC3F family of connectors and those are out of production and they are demanding $20 to $50 for one connector.
That is a ridiculous price and I would be tempted to swap out the connector for a more available design.
On eBay item 250401122616 is one but they want $13 pus $11 shipping which is a rip off.
These were used on some OLD CD radio mics.
Dec 15, 2009 | Behringer Music
Power supply cooked
There isn't anything in the power supply you cannot rebuild except the transformer.
BUT you should verify that something in the mixer didn't short out and damage the supply.
After you relace the smoked parts (likely the TOP245Y offline regulator chip is gonzo... then you use this trick to restart the unit safely:
Put a 60 Watt light bulb in series with the hot side of the input power line. I would recommend you use an ISOLATION transformer when working on the power line side of this for safety.
Jan 17, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Eurorack Pro 12 input rack mixer (Passive) Got no power supply. How do i fix them?
Hi
you mean no power? if no power check the primary fuse! i can teach how to fix that, if you are a electronic technician?
Thanks!
Sep 22, 2008 | Behringer EUROPOWER EP2500 Amplifier
781 people viewed this question
 Grubhead
Grubhead
