Question about Cameras
Nikon d80 shutter not working properly displaying err
    Genius:
  • 1,665 Answers
Have a look at troublshooting of your manual at link
http://www.nikonusa.com/pdf/manuals/noprint/D80_noprint.pdf
Posted on Jun 28, 2008
  • 13,433 Answers
You will have to send it to nikon for service, the contact details are in the manual.
If you have warranty that may cover the service. You can also try pressing the reset button / hole either next to the connectors or in the bottom.
Nikon d80 camera shows err error, when shutter is pressed the amount of shots remaining, shows er07. shutter works, but no picture is taken. Bracketing sign is also on display and wont go off.l
failure of the aperture unit is the usual cause - usually the contacts for the phase switch have come loose from the gear. You can find info on this by searching for the problem on the internet, including how to repair it.
Apr 06, 2013 | Nikon D80 Digital Camera
Nekon d80 erro problem
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Jun 01, 2012 | Nikon D80 Digital Camera
'err' sign on display nikkon D80, and appear r 15 when shutter button is press
"rXX" is just the camera estimate of how many pictures left on memory card. As for "ERR": while camera is in "On" position, take out battery and hold shutter button approximately 30 seconds. Turn camera "off, replace battery and turn "On" again. If thre is a hardware reset button (check manual carefully) while camera is "On" use that reset button/
Feb 19, 2011 | Nikon D80 Digital Camera with 18-135mm...
I have a Nikon D80 and one day, I suddenly couldn't take pictures. When I turn my camera on, it automatically blinks the Err message. My shutter mechanics work fine, it recognizes my lenses, and playback...
Had same problems. The shutter is faulty although my D80 only registered about 2,000 shots.
Get it fixed at Nikon Service Center. It's your only option. Cost me $120.
Aug 19, 2010 | Nikon D80 Digital Camera
I have a D80 since 2 years and since last 1 week have been getting the 'Err' message. Initially, after referring to the manual & pressing the shutter release button, the camera responded only ONCE. ...
Hi sandeepbhat2, On page 129 of the D80 manual is the factory reset switch. Look on the left side of the camera there is the terminal cover, inside below the USB connector is a small reset button. Give that a try. If still it does not work you should call Nikon.
Jun 27, 2010 | Nikon D80 Digital Camera with 18-135mm...
D80 err message . what can I do to fix without sending the cam in? I have already did the reset and nothing so far is working..
Page 132 of the D80 manual states the ERR is a camera malfunction. My suggestion is to rest the camera, see if that helps you will find those instructions on page 129 in the D80 manual. Sometimes removing the batter then pressing the shutter release numerous times will free up any static buildup. If none of that works it is off to Nikon.
Jun 20, 2010 | Nikon D80 Digital Camera with 18-135mm...
Err
The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Apr 05, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
"Err" appear in the viewfinder and LCD display
i have a Orite Mv 3115-Real Dv Mpeg4Vga resolution 30 FPS Digital Veidio Camera. no the problem that the battery of my camera down and i sent that with my friend to bay a new for me unfortunatly he miss that on travel so i need to fins a new battery for that
i hope sir you can healp me to find one and a charger too
Feb 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
Cameras Logo
75 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
