Question about Singer 3116 Simple
The bobbin tension on my Singer Simple sewing maching is way too loose.
    Genius:
  • 1,788 Answers
Is your thread unwinding the right way? Check your manual and watch the dvd that came with your machine. If, you can't find your manual go to www.singerco.com and download it for free
Posted on Aug 21, 2010
NO MATTER HOW I ADJUST THE THREAD TENSION ON MY SINGER 2950, IT CONTINUES TO SEW LOOSE BOTTOM STITCHES. THE TOP STITCH IS FINE, I HAVE RETHREADED THE MACHINE AND THE PROBLEM PERSISTS. ANY SUGGESTIONS?
someplace I read hat on some of these newer machines we need to hold the bobbin so it gets into the tension slot , which we can not see . while bringing the bobbin thread up thru the needle hole . I did try it and it is simple to do . just leave the bobbin cover off till you get ready to sew .
Aug 31, 2015 | Singer Sewing Machines
Thread bunces up on the bottom causing machine to
I would start by looking for a problem with the bobbin tension. Do you have the bobbin threaded through the case correctly? Is the the bobbin tension set to loose? Another thing that can cause it to spool up on the bottom is if it sews a bunch of stitches all in the same spot or real close, do you have the presser foot tension to loose?
May 23, 2010 | Singer 2263 Mechanical Sewing Machine
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Feb 28, 2009 | Singer 3116 Simple
I have a Singer Futura CE-100. I have had it for 3 years but have not used it much because I can't get the tension correct. I have had it repaired/maintained twice most recently this week. I can now sew on...
Sad to say you might have to do an indept check. Like start with a small peice of fabric - start with the highest bobbin tension and go to the lowest - leaving the top tension the same. Write all the findings. Then do it all again with the next top tension. Keep your 'good' findings in a little notepad in your sewing box. Then you will have it all ready for any other project. Good luck!
Jan 25, 2009 | Singer CE-200 Quantum Futura Computerized...
Problems with Singer 2732
Jan 02, 2009 | Singer 2732 Mechanical Sewing Machine
Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Dec 29, 2008 | Singer 3116 Simple
Singer 3116 Simple Logo
85 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
