Appliance i have an one year old central air conditioner (comfortaire heat pump). When installed they told me to change the filters every month. After a few months I realized my filter were never getting dirty. I scheduled the yearly maintenance on the unit. They said all was fun, but suggested that I change to a more expensive filter. I have changed filters but they never get dirty. I pulled the filter out and looked under at the "v" and noticed every week it is getting dirtier. What could be the problem???
  • ss98176 Jun 28, 2008
    Sorry, the brand should have been listed as Comfortmaker
    Scholar:
  • 104 Answers
The only possible explainations for your situation is that the air is either going around the filter and going straight to the coil or the air filter is on the wrong end of the furnace. The air should go through the filter before it goes through the furnace. If you can take the filter out and look at the coil, the air should be sucking into the furnace from that end, if it is blowing in your face, that is the problem. If all is ok with that then take a close look for where the air could be getting in without having to go through the air filter. Seal up any holes with duct tape or sheet metal or both.
Posted on Jun 28, 2008
My air conditioner quit working it is a Trane air conditioner it does not cool or heat will not come on at all it is 8 years old I have cleaned it every month I change my filters out every month
Did you change your thermostat? It may not be compatible. First try changing the batteries in the t-state and see if that solves your problem.
Oct 25, 2015 | Heating & Cooling
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
Sep 10, 2008 | Amana Heating & Cooling
I am installing a heat pump, and i having 8 flashes at my green LED .
look at page 17 here is all the install instructions plus troubleshooting
x air conditioner/heat pump
operates at reduced
performance.
x Air conditioner/heat pump
operating at low stage when
expected to operate at high
stage.
x Integrated control module
diagnostic/status LED's display
the indicated code
http://www.alpinehomeair.com/related/IO-348K%208.2013.pdf
Oct 06, 2013 | Goodman Manufacturing Goodman DSZC160601...
Need help ComfortAir mini split heat pump -froze up not defrosting...... What do i check
Check your out door fan is working or not. 2. May be short of gas. 3. Coil sensor in outdoor defective.
Dec 14, 2010 | Comfort-Aire ECW 18 Air Conditioner
My comfortaire dehumidifier stopped dehumidifing.
First of all, Is it collecting water?. If not then it most probably has a leak in its refrigerant system. If that is the case then you need to contact your local repair person/shop.
Jun 02, 2010 | Heat Controller PE121A Air Conditioner
Central air conditioner
check the filter also sounds like a low freon charge.
Jul 29, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
