Question about Apple iPod MA446LL/A MP3 Player
I have questions for any ipod user
Ok do you all leave the ipod charging longer than 2 days. I want to know also if leaving the ipod on charger say all month will it kill the battery faster? also should u let the ipod die completely before recharging it.
  • stroise256 Jun 28, 2008
    ok i found the battery for $8. What i wanted to know is if u leave the ipod on charge all the time does it shorten the life of the battery?
  • 158 Answers
No, it is not nesscarry to leave your ipod charging longer than 2 days, but I guess you can. It only takes a couple of hours for it to charge. I am not 100% sure that leaving your ipod in all month will kill the battery faster, but I don't think it will. Plus, wouldn't you want to listen to your ipod anyway before a whole month went by? You shouldn't let the battery die all the way before you charge it. It is harder to get it to turn on, if you let it completly die. Also, if your battery is low, I don't think that I would want to take the chance of it dieing on me at any time. If my battery doesn't have the plug symbol in it (which means it isn't fully charged), I go ahead and charge it anyway.
I hope this helps. Please rate my solution.
Posted on Dec 07, 2008
    Problem Solver:
  • 18 Answers
What is your problem? The ipod doesn't die. Believe it or not but there's a battery inside of the ipod that if you want it to be repaired. Don't send it to the apple company, they'll charge you a **** load to replace the battery. You can find an ipod battery $10-$30 easy on the net&the proper instructions on the net you can replace the battery yourself!
Posted on Jun 28, 2008
First My Ipod Was Dead For A Couple Days Than My Dad Went To Buy Me A Charger & I Put It On There & Its Didnt Work So I Keep It On The Charger For Three Days & Than It Still Didnt Come On So For Like A...
What type of ipod and how old is the battery ?
iPods have revolutionized the way we think about portable music and video players. Occasionally, however, your iPod may freeze and no longer turn on or off.
Luckily, there is a simple fix for this predicament.
Toggle the lock switch on and off several times, leaving it on the off position.
Hold the "Menu" and "Select" buttons at the same time until the Apple logo appears on your iPod's screen.
Repeat steps 1 and 2 if necessary, until the problem is corrected.
iPod Touch
Ensure the iPod will not turn on or off by holding the power switch down for at least 10 seconds.
Hold the "Power" button and the "Menu" button simultaneously until the iPod powers off.
Hold the "Power" button until the Apple logo appears on your iPod.
Aug 16, 2013 | Video Game Consoles & Games
My ipod wont charge when i plug it in
Hello, welcome to Fixya!
If your ipod won't charge, the fault should either be from the battery or from the means by which you are charging it.
If the battery is very weak, then it might not come-up when using charger or PC to charge it. Leave the ipod in the charge for about 6 hours and it should come up if the battery is weak.
But if it doesn't come up, then you have to check your charger. Test your charger with a friend's ipod. If the charge works with your friend's ipod then it means your battery is the cause of the problem.
The essence of the above test is to diagnose and get to the root of the problem. So that a precise/concise solution can be proffered.
I hope the above is clear. If not, please let me know.
Nov 17, 2011 | Apple iPod touch
I have a aaa duracell battery charger (2 batteries) and want to know should i leave the batteries in my microphone until they need charging or should i leave them in the charger until i want to use the...
Only charge rechargeable batteries when they are depleted of power. Once they are restored, it is okay to leave the batteries in the device but recommend removing when not in use to avoid contacts getting moisture in between causing corrosion, also the battery will leak some minimal power when installed/connected in the device.
Nov 24, 2010 | Audio Players & Recorders
If i leave a battery charging too long (several days) it screws up both the battery and the charger
Sure! read your manual! It says "don't leave the charger hitched up longer than 8 hrs!" the battery heats up and the internal overload opens so it starts to discharge. jeez!
Oct 22, 2009 | Black & Decker Black And Decker FS24C...
Ipod player wont charge ipod
I probably have the same type charger / player that I also purchased from Wal Mart. If it plays your ipod it should also charge it. Make sure the lock button on the ipod is unlocked and it's turned off. If that does not work keep it unlocked and leave it on. On systems like we have that are not iHomes they sometimes have trouble figuring out what brand they need to charge.
Aug 15, 2009 | Apple iPod nano MP3 Player
Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
Aug 12, 2009 | Motorola Radio Communications
Horizontal lines have appeared on the screen?
Its either because you dropped it some where or its because u charged it with some other charger other than the specified one. There are 2 solutions for it one is leave the ipod unused/untouched without any charge in it for 4 to 5 days. If u still get the line appearing on the 6th day then the only solution is to get it opened n try alligning the screen else replace the screen.
Jul 31, 2009 | Apple iPod MA446LL/A MP3 Player
Charging batteries
Hi Ava, thanks for coming to FixYa.
It is not good to leave your battery on the charger longer than 2 hours. Depening on your battery type, it should not take longer than 2 hours to charge up.
If you leave it on longer than that, it will get too hot, and might make a fire hazard. Also, the hotter the battery gets, it lessens the life of the battery.
Most battery chargers will not automatically turn off, so you should monitor the charging time.
Thanks for coming to FixYa. If you have any other questions, you can leave me a comment.
Mar 25, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Charging times
I would think not more than an hour or when the lights flash that the battery is charged. The newer chargers go to a maintenance mode after a battery is charger so theoretically you could leave it on for weeks, but I don't recommend this.
Jan 14, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Apple ipod not getting charged
What type of IPod is this? Also what type of charger are you using? If the ipod does not have a charge at all you will need to plug it into a wall charger for it to get a "Base charge" (this usually takes 5-10 minutes) as if the ipod is totally dead then there is not enough of a charge for the ipod to let your computer know it is there to start being charged. After it has the base charge you can use the usb connection to finish the charge or leave it plugged into the wall charger to finish getting the charge.
May 08, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
105 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
