Question about Uniden Lands Phones
Uniden FP204 - my phone has lost all of the phonebook. when I go into phonebook the dial shows time and date,then in the centre shows 2002 and displays SET TIME I cannot gain access to any other functions. Trevor Bell - 02 42712278
  • 1 more comment
  • trevortbell Jun 28, 2008
    Thank You for your help.
  • Anonymous Mar 16, 2014
    uniden fp204 wont ring when dialed
  • Anonymous Mar 18, 2014
    phone wont ring
    Genius:
  • 1,665 Answers
    Brigadier General:
  • 6,966 Answers
Offhand, the phone looks like has a corrupted memory or a systems glitch. initially, this would require a reset. Of course doing so would revert the unit back to factory default condition and all personal settings/configurations would be erased. Additionally, it would probably be helpful to check if the unit has a built-in memory battery that may be nearing end of its life.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 28, 2008
UNIDEN FP204 TELEPHONE DOES NOT CONNECT TO AUSTRALIAN TELSTRA PHONE LINE ie NO DIAL TONE - UNABLE TO RING OUT OR RECIEVE A CALL
you should Verify that you are using the correct line cord and that it is plugged in correctly.
May 28, 2010 | Lands Phones
Uniden Model FP204 Even with all controls on high
GAVE UP Obvious fault with the Model Hard to hear even with all
Volume controls on high
Jan 13, 2010 | Uniden Lands Phones
User manual for Uniden Telephone model FP204
This is a link to a pdf user manual for a uniden model number FP204 you can view this item on line or download it to read later Hope this has fixed ya
Dec 18, 2009 | Computers & Internet
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Speed dial on uniden
When the phone is not in use, press and hold the number key (0-9) that is assigned to the phonebook entry. Press flash on the handset to dial the number.
Apr 23, 2008 | Uniden DCT756-3 Phone
Press 1 for English
Do you possibly have the phone set on Pulse dialing when your phone company only supports Tone (or vice-versa)? Hit Menu, select Global Setup, then Dial Mode, and see which is selected. Try the other and see if that fixes it.
Sep 30, 2007 | Uniden TRU9480 Cordless Telephone
Lands Phones Logo
198 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
